Results 1 to 8 of 8
    Active Member NVERLAST1's Avatar
    Nov 2011
    charlotte,nc
    Default replace wheel bearing?
    How often do you replace? How do you know when you need to replace?
    Default Depends...
    If you don't do your own work you would have to see the signs. If dealer does your work they will let you know, one hopes. I always have a set on hand but have 42,000 miles and my third rear tire and the bearings are still good. Best time to check them is when you replace the tire.
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    ….. I also have over 42,000 mi. and my Bearings are fine …… some folks change bearings at every tire replacement, which to me seems a waste of funds …… jmho …. Mike
    Nov 2011
    charlotte,nc
    Wheel is apart. Bearing in sprockets turn smooth but ones in wheel turn like they dry or have sand in them. Makes a grind noise when turning then kinda stops where as other bearing keeps turning. Is that normal? They not loose or anything they make grin
    Mar 2013
    Time to replace any that are not smooth and turn easy.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    May 2013
    Edmonton Alberta, Canada
    My rule of thumb is that I replace them every other rear tire change.
    As I do my own work on my Spyder it only the cost of the bearings and that's worth the piece of mind I receive in return.
    2014 RT-Ltd , Cognac
    Very Active Member Big Arm's Avatar
    Jul 2008
    Sioux City, Iowa and Tucson, AZ
    QUOTE=Purple Guy;1420397]My rule of thumb is that I replace them every other rear tire change.
    As I do my own work on my Spyder it only the cost of the bearings and that's worth the piece of mind I receive in return.[/QUO
    ......couldn't agree more.....I'll be changing mine again on the next tire change, '08 GS 41,000 miles........ I'll send you a personal message of the numbers of the bearings and seals and o-ring
    2008 GS.....PE # 2888
    Nov 2011
    charlotte,nc
    I can't get that but to move what am I doing wrong?????
