Clock on dash still not working....
Anyone else have this issue? Everytime I start the bike it goes back to zero.
2020 Can Am Spyder RT Limited "The Comet #2"
Baja Ron Sway Bar
Passenger Armrests From Can Am
Wolo Big Bad Max Airhorn
Lamonster Top Cuff W/Ram Ball
Lamonster Power Plate
Tackform Phone Mount
Key Cover from Ebay
Lamonster Mirror Locks
Ultragard Cover from Lamonster
Top Grills from Spyderpops
Garage Door Opener from Spyderpops
3.5mm Extension from Amazon
Lamonster USB Cable Holder & Cable
Foam Grips from Spyderpops
Tricled Strobe Brake Light module
Tricled Bag Lights (replace reflectors)
Tricled Turn/Brake/Run Signals Rear
Tricled Floorboard Lights
Tricled Sequential Run/Turn Fender Lights
Tricled A-Frame Run/Turn Lights
Tricled LED American Flag Mount & Flag
Showchrome American Flag
mine looses time horribly, but does not go back to zero
2017 RT-S
Bump Skid - Spyderpops
Wrap - Wrapmyspyder
swaybar - Bajaron
Sena 20D & SM10
3 PC Mesh Zippered Lid Net Set - TricLED
A arm LED's - Safety LED's - TricLED
Mirror Sequential turn signals
Glo-riders
LED rear turn signals and reverse lights
Front Grills
Third Brake light
Larson Scanner
Light Up - Sue Hopper
The actual clock should never register ZERO......well unless maybe it is set for a 24 hour display.
If you are indeed looking at the clock and not another number by mistake..............
Either it is broken or you are totally losing power at some point in time, which might be a loose connection somewhere or the battery going bad.
What do you mean by 'still' not working?
2014 RTL Platinum
Interesting....🤔
There are two clocks on the spyder.. one normal clock and the engine operating time clock (this one only shows hours and is the only thing constant even if you change the instrument panel) the only ones that reset to "0" , but you have to do it, are the trip meters. Could try a battery disconnect and re-connect so things start all over and if still a problem a call to BRP might help. I have never seen it only the fact they are not very accurate....
2012 RS sm5
https://www.spyderlovers.com/forums/...view-the-clock
2013 STL SE5 BLACK CURRANT
SpyderPop's: LED bumpskid
minispyder dash toy
Lid lox
KradelLock
Pakitrack
FLO (Frunk Lid Organizer)
BRP fog lights, trailer hitch
SENA 20S EVO
I ride, never worry about time but then I'm also retired
2011 Spyder RT-S
LtCol, USAF Ret
Proud Patriot Guard Rider
Buy a watch and strap it on the handlebar.
Hi Chupaca,
Thanks for posting. Where is the other clock supposed to be? The same place? Is there some trick to turning it on?
Thanks,
Fin
Baja Ron Sway Bar
Key Cover from Ebay
3227 Days and I will not worry about it either..... But until then, it would be nice to have a clock there.
Baja Ron Sway Bar
Key Cover from Ebay
Fin, Did you take this issue to your dealer and what did their tech say?
Safe Rides,
David and Sharon Goebel
Both Retired USAF Veterans
IBA 70020 |
The time should be displayed in the top bar of your main center display, right next to the temperature.
But the characters are pretty small.
Hi Chupaca,
Thanks,
Fin
Have you read the owner's manual?
2014 RTL Platinum
not the same problem but clock loses aboiut 2 hours every day--- have asked several cert mechanics but no real answer
This is not something that can be "fixed".
Like most modern digital clocks, if it doesn't work the whole "chip" that runs the clock needs to be replaced.
In the case of a Spyder, that might mean a whole assembly.
IF yours is still under warranty, they should fix it.
No way they can claim that two hours a day is "normal".
If it is not under warranty and it has not always done that.......it might be an early sign that your battery is going bad.
I'm still wondering if the OP FinFan3DP has taken his clock issue back to his dealer?
Safe Rides,
IBA 70020 |
Could be the trip elapsed time option.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
This is my low-tech solution to the worthless dashboard clock
2014 RTL Platinum
That's what it is doing, but I can't find how to change it to strictly a clock.
And for all the people that are saying just add something, or what do you care cuz it doesn't work well anyway, please don't respond.
Baja Ron Sway Bar
Key Cover from Ebay
Then how about responding to my question of 'have you read the owner's manual'?
How about responding to another post re: is it under warranty? And, what does the dealer say about it?
2014 RTL Platinum
Not to sound insensitive Pete, but that's what these forums are for, so ONE doesn't have to reinvent the wheel or read a manual. You have a question, and hopefully, someone has already had the issue before and can enlighten the group. Again, if you don't have an answer to my problem, please don't respond.
Baja Ron Sway Bar
Key Cover from Ebay
Okay.
2014 RTL Platinum
FINFAN3DP, I have a 2018 so I cant look at mine. I did see a video of an older RT and I saw the option menu with (preferences) so maybe look in there?
Try this................ I copied from another post
Peter Aawen
Peter Aawen is online now
Ozzie Ozzie Ozzie
Peter Aawen's Avatar
Dec 2013
Aus, Sth Aust, Adelaide Hills
Post Thanks / Like
Quote Originally Posted by Habib View Post
Go back in where and do what? It was fine the way it was and for safety I disconnected the battery while I did some hook ups. Do I disconnect the battery again?
While I'm pretty sure it's in the 'Frunk Manual' (well I can't call it 'Glovebox Manual' can I? Cos it sure won't fit in there! ) Sooo.... Let's see if I can remember how to do it..... OK, here goes:
Press the Mode button (that's the very top left button on your RT or F3-T or Ltd Left Hand grip) a few times until the Set-up screen appears; then using the Navigation arrow buttons, navigate down the list first & then across (right) the list until you find the item/display you want to change; then go right once more to select from the list of display options shown. Once you've selected the option you want, use the Nav arrows to go up & back (left) to the top of the menu & then the Mode button to leave that Set-up screen (cos if you don't leave the menu options area you might accidentally end up changing what you so laboriously just fixed the way you like it if (when) you accidentally hit the Mode button often enough or you disconnect the battery & it reverts to your chosen 'default' )
AFAIK, those Spyder Models with the 'less comprehensive' dash display still achieve the same results by using the M & S buttons in the Dash & scrolling thru the (less comprehensive) display options in much the same manner - someone with one of those models will correct me if I've got that wrong I'm sure!
