Results 1 to 11 of 11
    Oct 2015
    Lynden, WA
    Default Elec Power available on ST-S for heated gear?
    I just inherited heated liners. A 90W FirstGear Jacket liner, Pants liner and Socks.
    I'll be using a 2 zone PWM heater controller.
    Do I have enough electrical power on my 2013 STS SM5 to run this gear?
    I switched the headlights to LaMonster LEDs so that should free up a few amps.
    I have OEM heated grips and have added additional LED turn signal lights and driving lights.
    I may be taxing the magneto. I guess I have to get out the voltmeter and make some measurements.
    Please advise of your experiences.
    Thanks,
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Bossier LoUiSiAna
    Constant 90W?
    Very Active Member Zip's Avatar
    Sep 2016
    LI NY
    Hey Haze.
    I have a 2010 RTSM5. I use a Hotwired 12V Heated Jacket Liner and gloves everyday. Combined they are 96W and 8.2A. I have no issue. I get to work in the am where the bike sits outside for 9 hours (today it was 19F when I got to work) and it starts right up when I leave for home. I store the bike in an unheated trailer at night with the tender on. So to answer your question I see no issue using your gear.
    2010 RTSM5
    2010 RTSM5 , stock Stock Silver
    Nov 2012
    North Las Vegas, NV
    You would only use 90W on high. I don't think you could stand it that hot.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Oct 2014
    Fort Mill, SC
    90 watts will be 7.5 amps. Be sure you hook upto a circuit that will handle at least that.
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    Nov 2012
    North Las Vegas, NV
    I agree,direct to the battery is best.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Not a problem. Hook direct to the battery with an inline fuse and you will be fine. I use two heated jacket liners and gloves with dual control for me and single for the wife and we never have a problem....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Oct 2015
    Lynden, WA
    Thank you to all for the responses.
    I have a direct hookup to the battery thru my auxiliary fuse block.
    As soon as the snow/ice and salt are gone I will test the new heated gear.
    Thanks again.
    David C.
    David C
    2016 F3T
    Rear IPS Pack Rack
    Apr 2014
    full time RV'er on the road. Well we were. Now, 6 months in ThreeRivers Mi and 6 months in Apache
    Wow, here I am sliding in on a thread and picking up some knowledge. My wife and I have some older Gerbing jacket liners left over from the Gold Wing days. We have never tried to use them for all the reasons mentioned above. I guess I better see what the wattage is and re-think the proposition. The older Gerbings operate with a pulse method of temp control. Don't know about the newer. Highwayman is right, even Alaska we could never stand to be even at half throttle.
    Thanks for this post and all the feedback.
    Sep 2018
    greensburg,pa
    Go off the back of alternator + a lot closer!
    2018 RT-L , Blue
    Quote Originally Posted by bluewoo View Post
    Can't do that Blue, 2010 Spyders have a mag, not an alternator!! The alt's came in with the 1330 motors; so in this case, where the OP, Haze, has a 2013 ST that has the 998 V-twin, connecting to the battery is still the best bet!
