Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 55
  1. #26
    Mar 2013
    To answer Ann's question the last two Mitchlan Premier A/S tires averaged 24,000 miles each.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
  2. #27
    Dec 2015
    Oakley Utah
    Quote Originally Posted by PW2013STL View Post
    I have had great success running Mitchlan Premier A/S tire. If you look it up in TireRack the description states it was designed to be the best wet road tire. I found it so on our RT.
    The closest size I've found in this tire is 195/60-15. Is that what you're running? https://www.tirerack.com/tires/tires...REAS&tab=Sizes
    2014 RTL Platinum
  3. #28
    And the 205 is the surface width of the tread, I think. Is a wider tire (like the 235) better or worse for what I'm trying to do? Or, maybe the issue with the wider tire is clearance at the swing arm...
    235 ?????? ……….. I never said 235 …. and 205 COULD be the tread width …..OR NOT …… tire specs usually list sidewall width and tread width separately ….. Mike
  4. #29
    Something to consider about Tire sellers ( or anyone who sells things ) …… They list what they have to sell ….. To get the MOST accurate product information is by going to the Manufacture's WEB site …….ie Google " Vredestein Tire co. " …. This is where I get my Vredestein tire measurements from....All manufacture's have their own WEB sites …..not always easy to find, because most search engines are skewed to the search engines MOTIVES ….. Mike
  5. #30
    Mar 2013
    No.
    205/60 x 15 is what I ran. Purchased from Costco. TireRack use to have the 205 in stock.
  6. #31
    Dec 2015
    Oakley Utah
    No.
    Michelin's own web site has no 205 in a 15" that I could find.
    2014 RTL Platinum
  7. #32
    Dec 2013
    That 195 width is going to be too narrow for the rear rim on a Spyder & too wide for the OE front rims too! (I dunno about the Rykers, what rim widths do they run?) Some 205's might be a tad hard to get onto that rear rim as well, so you will need to check the actual physical dimensions before committing, but you can probably look at tires between 205 and 225 in 50 to 60-65 profiles; bearing in mind that the stock tires are 225/50's & if you go down one size in width you will usually be fairly safe to go up one size in profile & still remain fairly close to the same rolling diameter.
    That means you could try 215/60's or 205/65's & they should be close; but once again, you'll need to check the ACTUAL dimensions not the nominal tire sizes to know for sure! For example, I think it's the General Altimax 205/55R15's that are almost identical in rolling diameter to the OE Kenda 225/50R15's.
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
  8. #33
    Mar 2013
    All Brands Michelin Premier A/S 205/60R-15 29199
    IMAGE DISCLAIMER
    (6)
    205/60R-15
    Part Number: 29199 Service Description: 91 H UTQG: 640AA Sidewall: BW Load Range: B (4 Ply) Treadlife Warranty: 60000 miles Type: Passenger All Season
    View Full Specs & Details
    FREE SHIPPING
    RISK-FREE GUARANTEE
    Today's Price
    $106.98
    https://simpletire.com/michelin-205-...%2091H%2029199
  9. #34
    Mar 2013
    Michelin Premier All-Season Highway Tire 205/60R15 91H
    Average rating:3.5out of5stars, based on30reviews
    30 reviews
    MichelinWalmart # 556257265
    $120.99
    Other costs
    Free shipping
    https://www.walmart.com/ip/Michelin-...20r-15&veh=sem
  10. #35
    I just checked the specs for the Michelin Premier ...195/60-15 …. they say it will work on wheels/rims between 5.5 & 7 inches ………. I believe the rear wheel on the RT ( and others ) is 7 inches ………. Mike
  11. #36
    Dec 2015
    Oakley Utah
    30 reviews
    $120.99
    Other costs
    Free shipping
    I'll be hornswoggled! Thanks!
    2014 RTL Platinum
  12. #37
    Active Member Richardv's Avatar
    Oct 2014
    Montreal north shore, QC
    Quote Originally Posted by asp125 View Post
    I think he means Toyo Proxes 4
    ...Yes, Toyo Proxie 4 in 225/50R15. see my signature
    Richard
    * 2012 RS SE5 (hers)
    * 2013 ST SM5 (mine)
    Daughter RSS SE5 2014
    Son in law RSS SM5 2013
    P.S. 3 Kumho AST 225/50R15 and 1 Toyo Proxies 4 225/50R15 rear tires
    2 sets of Kumho 175/55R15 front tires
    1 set of Hankook V4
    1 set of Canadian Tire General tire Evertrek RTX in 14" for the 2012 ...
  13. #38
    Dec 2015
    Oakley Utah
    Check out Vulcan Tire Sales as they may have this size.
    They want $30 shipping!
    2014 RTL Platinum
  14. #39
    Dec 2015
    Oakley Utah
    I tried buying the Vredestein, but the places I tried are out of stock (or they want $30 shipping).
    So, found the Michelin Premier A/S in 205/60-15 at SimpleTire.com for $91 and ordered it. Joe Meyer will be installing it for me. Thanks for all the great feedback.
    2014 RTL Platinum
  15. #40
    Mar 2013
    FYI - I ran mine at 18# pressure, and got the best wear and mileage. This was riding two up 95% of the time and with a loaded RT 622 30% of the time.
  16. #41
    Dec 2015
    Oakley Utah
    That's good to know. Thanks.
    2014 RTL Platinum
  17. #42
    Sep 2016
    Chillicothe, Oh.
    I also run 18 in my General and with 18,000 miles on it it still has plenty of tread and still does great in a heavy rain. 95% of my riding is two up as well and maybe that has something to do with the traction in the wet. When traveling solo I am on two wheels.
    2015 RT , Black
  18. #43
    Active Member WisconsinDavid's Avatar
    Sep 2018
    Beaver Dam WI
    Is this the size of Quatrack that folks are running: Vredestein Quatrac 5 205/50-15. Fitting it on a 2010 RS. Thanks.
  19. #44
    Quote Originally Posted by WisconsinDavid View Post
    That would be the perfect size for the RS / GS etc. …… and at 18 psi it will give the best all around performance ………. Mike
  20. #45
    Jul 2010
    Las Vegas, NV
    See you next week! Joe
    Joe Meyer
  21. #46
    Sep 2018
    Beaver Dam WI
    Ordered the Vredestein from TireRack... 104 to be delivered today. Great service always through them (in my experience). Will put on before spring, when the garage warms up a bit and I do too. Thanks for the information. 18 psi it shall be, make it so!
    UPDATE: Ordered and delivered next day. The tire's tread pattern is impressive. I'm looking forward to getting this on the rear wheel and seeing how it handles dry and wet. Thanks again for the great source of information this board provides!
  22. #47
    Very Active Member Fat Baxter's Avatar
    Sep 2014
    Central Alabama
    FYI for those who are happy with the General Altimax RT 43: Walmart carries them for about $80.
  23. #48
    Mar 2016
    Palm Harbor, FL
    I’ve got this 205/55-R15 waiting in the wings for my 2016 RTL.
    https://www.tirerack.com/tires/tires...WR5S&tab=Sizes
  24. #49
    Active Member Lobo's Avatar
    May 2016
    Murrels Inlet, South Carolina
    Does anyone have experience with Kumho Ecsta AST - 225/50R15 91H Tire?
    2015 Spyder RT-S Special Edition. Two Brothers Racing exhaust.
  25. #50
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Lobo View Post
    Are you asking generally, or specifically to its wet-weather performance?
    2014 RTL Platinum
