Results 1 to 25 of 48
    Active Member nealperkins's Avatar
    Feb 2017
    Fort Myers, FL
    Default Battery electrical leak
    Well, I 'think' I have one. How would I check this with a volt meter?
    I guess the battery could be shot but, it is kept on a battery tender full time so, that 'should not' be the issue.
    Thanks!
    2016 F3T Limited
    F4 Windshield, LaMonster backrest, headlights, foglights with rings, Long Horn mirror lights, saddle bag and fender lights, swaybar, cat bypass, Centrtonics balancers, Fobo, Baker hand and lower wings, laser alignment, Dual power plate,Givi E47 center bag, Sensa 20s, Pitbull highway riding pegs, Tricled highway lights, empty bank account
    Quote Originally Posted by nealperkins View Post
    Thanks!
    Well unfortunately a CHARGED reading on a Tender or Maintainer is not a guarantee that the Battery in question actually has a Full charge.... I have had false readings on a few batteries I have had on a Maintainer ………. someone will explain the Volt meter thing …… Mike
    Mar 2015
    forrest above Reno, Nv
    A test light will do the trick. Un-hook the negative side of the battery and put one side of the test light ( usually the one with the clip ) on it. Then touch the probe/lighted light end to the negative cable end. If the battery lights---- you have a leak somewhere. These test lights are very useful if you're looking for a hot wire ( ignition on or off ) on your car or spyder.
    Lew L
    Last edited by Peter Aawen; 02-02-2019 at 11:12 PM. Reason: speeling & tersting too!
    2014 RTS , Circuit Yellow
    Apr 2017
    North Central Florida
    Thanks!
    Wrong conclusion.
    All batteries eventually wear out.
    Keeping it on a tender will only extend the time to death, not eliminate it.
    If you think your battery is bad, then it probably IS.
    After you get a new one, the charging voltage of the tender should be checked.
    A good float voltage is somewhere around 13.2 volts.
    The new battery should be fully charged BEFORE installing it.
    Sep 2014
    USA
    I agree with Mike- Dont trust the battery Tender either. I would unplug and plug back in at times just to be sure its working.
    Mine has looked good showing green but when it was time the battery was dead.
    You can always take the battery to a autozone and they can test it for you too.
    Faribault, MN
    Quote Originally Posted by Lew L View Post
    A test light will do the trick. Un hook the negative side of the battery and put one side of the test light ( usually the one with the clip ) on it. Then touch the probe/lighted light end to the negative cable end. If the battery lights---- you have a leak somewhere. Th Lew Lese terst lights are very useful if you looking for a hot wire ( ignition on or off ) on your car or spyder.
    Lew L
    Lew, What's a "Lew Lese terst lights"? Is that an LED test light or something different?
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    NorCal - Northbay
    A test light will do the trick. Un hook the negative side of the battery and put one side of the test light ( usually the one with the clip ) on it. Then touch the probe/lighted light end to the negative cable end. If the battery lights---- you have a leak somewhere. Th Lew Lese terst lights are very useful if you looking for a hot wire ( ignition on or off ) on your car or spyder. Lew L
    There can be "draws" that are enough to light a test light and still drain a battery. I would use a DVOM (Digital Volt/Ohm Meter) personally....
    OP, just because the battery shows a "full" charge doesn't mean that it isn't what we call a "surface charge". While it "looks good" it will fail under a load test (like when you go to actually crank it) due to things like sulfation, specific gravity reduction etc... If you are sure your connections are tight and the "maintainer" is working correctly, take the battery to an auto parts place and have it load tested. It most likely will fail....
    Chuck
    Apr 2017
    Quote Originally Posted by hypurone View Post
    There can be "draws" that are NOT enough to light a test light and still drain a battery..
    I think you left out a "not" there.
    Dec 2015
    Oakley Utah
    Thanks!
    Why do you think that?
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    Electrical 'leak' and failing battery are two very different things.
    2014 RTL Platinum
    Apr 2017
    Not to a novice they aren't. They look almost identical without some simple tests.
    AND.....the failing battery often "self" discharges at a really high rate.....which is essentially a "leak".
    Dec 2015
    Oakley Utah
    Which is why it would be more helpful for him to explain what the symptoms are rather than saying he thinks he has a leak.
    2014 RTL Platinum
    Mar 2015
    No it isn't. My left pinky finger hits the wrong key and words get transposed, inserted, ect. I'm suggesting a simple test light, inexpensive at any auto parts store. Again--- they are very useful.
    But thanks for pointing out my poor typing------ I've corrected it in the original post so as not to confuse anyone.
    Lew L
    Mar 2015
    If it lights the test light even a little, current is flowing. Yes I have a $100 Fluke VOM------ but for the simple stuff I use a $5 test probe and it works great.
    Next go to the fuse block. Using the fast and easy to use test/light probe and look for current flow. EASY to locate which circuit is draining the current.
    Bossier LoUiSiAna
    FYIit may be any combination of things Batteries don't like the cold either. A good load test is in order & maybe a full charge not just a maintainer. The battery proably could use some cycling if been sitting too long, made to be used not sit is another helpful aspect of a load test & by all means good time to clean terminals & connections ,just for reassurance
    Dec 2015
    Oakley Utah
    Lew, doesn't the test light probe just indicate the presence of voltage? Not sure you can check for current with one of those. Maybe I'm not understanding your post.
    2014 RTL Platinum
    Thanks!
    First of all, there are electronics on a Spyder that draw power all the time, even with the ignition turned off. If your battery runs down enough to not start the bike after about 2 to 3 weeks then you probably have a battery that is about to die. If it takes 6 weeks plus to draw down enough to not start, the battery is probably OK.
    As others have said, keeping it on a tender does not guarantee that it will stay it top notch condition. The main benefit of the tender is to replenish the charge that all the electronics sap away while the bike is sitting not doing anything.
    Mar 2015
    Lew, doesn't the test prove just indicate the presence of voltage? Not sure you can check for current with one of those. Maybe I'm not understanding your post.
    Hi Pete,
    If the light on the probe lights up-- current ( even a little ) is flowing. If we'er talking one or 5 milli amps, it might not light up. The quality VOM is the tool for that. The electrical potential ( voltage ) is there but not flowing ( current or amperage) unless there is a closed circuit with a load( A light, clock, computer, ect.) .
    Neal,
    Just a thought here. You have ALOT of electrical things added to your . Consider checking all connections and wires for chaffing
    The last time I used the light/probe I was installing Muth signal mirrors on my wife car. Used a wire diagram from Chevy and checked it with the pointy probe in a few seconds. Easy Peasy.
    There must be an electrical genius on the forum who can explain it more simply than I.
    This problem COULD boil down to a loose battery connection. It has happened to our 's many times as queried about on this forum. I believe I would start with a quality VOM and measure battery voltage with the motor running and then not running. The OP's spyder seems too new to have a bad battery, but heat and vibration kill our 12 volt batteries. I still have the original in my and just replaced the battery in my 2006 Magnum RT. Yes, 12 years on the original battery
    Hope winter is being good to you guys in southern Utah. We are about to get blasted again. Feet of snow is predicted.
    Lew L
    Dec 2015
    Oakley Utah
    Hi Pete,
    Now I get it. You have the test light leads in series with the circuit. I hadn't thought of doing that, but it does make sense.
    2014 RTL Platinum
    Mar 2018
    Florida
    Thanks!
    How old is the battery? 3 years is about the max to expect. Once a battery is shot, no amount of charging will bring it back to life.
    Feb 2017
    Fort Myers, FL
    Sorry for the delay. The battery is only 1 year old, maintained on the charger. But, it is a bit slow to turn over, even for a second crank when warm. I’ll have it checked but, I will just replace it if any weakness shows up...it is not worth getting stranded!
    Thanks for all the good info!
    2016 F3T Limited
    Dec 2015
    Oakley Utah
    That's more likely a bad connection, not a bad battery, I think.
    2014 RTL Platinum
    Has anybody asked about how many riding seasons that battery has faced?
    If iut's more than three: there's a good chance that it's ready to be recycled.
    Sep 2014
    USA
    How warm is the oil? I turned mine over in - 30 deg weather and yes it was slow but it started. And my battery is 5 years old.
    Bike will turn over slow when oil is a bit thick too.
    INDIANA, USA
    Default Battery
    I would remove the battery and then have it 'Load Tested". Auto Zone will do this for FREE. Good Luck
    ENJOY YOUR LIFE WITH A SPYDER
