Results 1 to 4 of 4
    Sep 2016
    Chillicothe, Oh.
    Default Dim right fender lights
    Have you changed the lights or done any work to the right fender? If you have a problem after changing something that is the first place you start looking. Check the voltage to the lights. If they are getting the same voltage as the brighter lights on the left fender then you need to check the ground circuit. Lots of time spent looking for voltage issues when it is actually a grounding issue.
    2015 RT , Black
    Dec 2015
    Oakley Utah
    Quote Originally Posted by nyfdtsdemt View Post
    My lights are dim on my right fender
    2012 RT
    Hi there, Corpsman 1st class! Former ET1 Nixon here. Tell me more about what you are experiencing, when did you notice it, how long have you had the bike?
    2014 RTL Platinum
    Just a shot in the dark (pun intended). Check for bad ground.
    Active Member nyfdtsdemt's Avatar
    Jul 2008
    Wilmington, NC
    Default here is the story
    I have the side lights and the top fender leds on that side
    The wires broke on the LEDS and i started to take it apart and the i noticed they are darker than the other side
    I think i should replace the wire that feed the bike to the tip light
    HM1 Nathaniel V. Mitchell, USN, CC-NREMT-P
