Results 1 to 14 of 14
    Jan 2019
    Edmonton
    Default Ryker and a Trailer
    Hello all. This will be be my first foray into three wheels. I will be picking up a Ryker Rally in March or April, depending on our snow levels.
    I'm a little disappointed with the limited storage options on the Ryker as I still hope to do the odd overnight trip. I've seen plenty of Spyders pulling trailers but I don't know if that easily translates to the Ryker. Are the rear axles similar or will somebody have to design a unique hitch?
    I'm curious what you all think on this. I'm not planning on any cross country trips, more likely a four hour ride to the mountains. I understand the Ryker is not a touring machine. I already take a break every 1-1.5 hours on my bikes so I expect the Ryker will be the same.
    I prefer gravel travel so I debated between the Ural and Ryker Rally. The Rally won out for a number of reasons.
    I'm moving away from two wheels for medical reasons.
    Thanks in advance for your insights and advice.
    Phloid
    2018 F3 Limited , Black on black
    Bossier LoUiSiAna
    Gotta wait & let the new settle in, hopefully there will be something not requiring a trailer mode the Ryker does not seem to have heard it has a Sport mode. Until then they offer the accessorie bags
    Jan 2019
    Edmonton
    Thanks @Bfromla, I didn't realize Spyders have a tow mode. I spent some time reading up on it but not overly relevant because of the transmission differences. So I looked to an automotive forum to read up on CVT's and towing. That was about as productive as reading a "what oil to use" thread on a dualsport forum.
    I suspect someone will cross this bridge before I get to it.
    The offered accessory luggage would suit me fine if I planned to motel my trips (although a single saddlebag triggers my obsession for symmetry). I'd still like the option of tent and sleeping bag.
    May 2010
    Windber,Pennsylvania
    The single sided swing arm is going to make it a challenge for sure.
    Bossier LoUiSiAna
    Hammock tent
    Feb 2019
    England
    Hi all this is what I have made (you must have max mount ) two holes drilled through alloy mount straight through . A piece
    Of 1/4 alloy plate 4in wide and long enough to extend past back o f bike and to take the givi waterproof bag which is
    20ltr size 16 wide/ 7/1/2 deep / 9in across top , drill holes in base of givi to secure to alloy plate , use button head bolts so that my comfort seat slides over max mount it is calculated to be 2in from pillion grabs and I use little existing straps on bag I wish I could put pics on forum but don't know how!!regards Nico 75
    Bossier LoUiSiAna
    Quote Originally Posted by Nico75 View Post
    PM sent
    Active Member mikeyuberalles's Avatar
    Feb 2019
    Clearwater, FL
    Page 70 of the manual states
    Do not tow anything with the vehicle, it is not designed for this application.
    In addition, the VSS will not be effective, you will be more likely to lose control.
    Bossier LoUiSiAna
    lil email help &
    image.jpg upside down pics
    Last edited by Bfromla; 04-05-2019 at 06:09 AM. Reason: I tried yall, just ain't got that trick figged yet
    Bossier LoUiSiAna
    Trying again with pics:IMG_0577.jpgIMG_0586.jpgIMG_0586.jpgIMG_0583.jpgIMG_0584.jpgIMG_0580.jpgIMG_0574.jpg
    Faribault, MN
    I saved the picture to my computer, flipped it and saved it, then could put this back.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    May 2010
    I don't believe the Ryker is the right choice for pulling a trailer for a number of reasons, including the clutch, the single sided swing arm, and the relative light weight of the machine. Any other Spyder would be a better choice
    Feb 2019
    England
    Hi all ref pics brake pedal extension is about double length of existing one Very hard to drill the two holes , but can be done
    I used 1/4 alloy , countersink holes so boot won't catch , it's a lot better to use than little one .
    Front suspension springs a covered with a type of cable protection, split along length so that you can press on springs and it grips start at top of Spring own work down and around ( it's hard work ) snip of with side cutters
    Regards Nico 75
    Bossier LoUiSiAna
