Results 1 to 10 of 10
    Feb 2019
    Illinois
    Default Newbie here - 2013 STS with whining noise?
    Just got a 2013 sts and I’m hearing a whining noise, took off the left plastic and disconnected what looked like the mass airflow sensor and it stopped. Turned the key to the on position and it started making noise again. Is this normal or is something causing it to somehow have power to it constantly?
    Hi Demar, welcome to the wonderful world of Spyders, SpyderLovers, and the Miles of Smiles you have to look forward to!
    That whining noise after you shut down is normal and is meant to be there! It can last for 30-40 minutes after shut-down; it's actually a servo holding the butterfly closed in the air intake. I believe it was extended out to last that long after a few Spyders had 'engine run-on' &/or burning issues - as in, call the fire brigade type burning issues! So you REALLY DO want it to be making that noise!
    Vermont
    Let the smiles, and miles begin! Also, let the farkles begin!
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Feb 2019
    Illinois
    Ok thanks very new to the spyders
    Nov 2018
    Waynesboro, PA
    Hello and welcome to the SL forums Demar1230. Hope you enjoy your time here, lots of good information in all the different areas. Peter may be right about the noise. 2013 had some changes made. maybe someone else will chime in but look around until then, try the search and add the year 2013.
    2012 RTL , Brown
    Feb 2019
    Illinois
    Active Member bscofield84's Avatar
    Aitkin Minnesota
    Had the same question on mine 2014 also. This is a great format for getting your questions answered.
    Congrats on your new ride. Welcome to the group.
    2014 ST SE5 LT , Black Current
    May 2012
    Panama City, FL
    on your spyder and to the spyder web. Dale
    Default There you have it....
    But welcome to the spyder world and this most informative site...enjoy your new ryde and we will be here to help anytime....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Oct 2015
    Lynden, WA
    Welcome to the Spyder world from Carson City, Nevada.
    The STS is a great machine that offers miles of smiles.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
