Results 1 to 5 of 5
    Jan 2019
    AZ
    Default Panel covering instruments
    I want to remove the plastic panel that covers the main instruments on my 2013 RT. Looks to be 4 screws. My question is will the panel come out and leave the main cluster in place or is the panel attached to the instruments. TIA
    Very Active Member AeroPilot's Avatar
    Nov 2012
    Pueblo Colorado
    The plastic panel (bezel) comes right off after removing the 4 screws. However, cover all of the gaps below thee dash especially the gap around the steering column as these screws are a special head size and once you lose a screw, you will have to order the OEM ones--- or have a screw loose and you dont want that.. haha
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
    2015 RT , OEM Black Gloss
    Default All together....
    but the whole thing comes out as a unit. You can disconnect the wiring and set it aside depending on what you want to do.
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Nov 2012
    North Las Vegas, NV
    The main cluster stays, the analog gauges (Temp and Fuel) come out with the panel and you have to disconnect the wires.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Jan 2019
    AZ
    Thanks all. Answered my question. Much appreciated.
