Results 1 to 10 of 10
    Nov 2018
    N.E. Ohio
    Default Ryker drive train
    I know that this was briefly talked about before but, the clunk when backing up or taking off, will this noise get more quiet or louder after break in? Maybe some of you folks that have this set up in ATV's will have some information to ad. cueman
    Active Member Tslepebull's Avatar
    Dec 2018
    East Texas
    I can only speak for my experience with 250 miles on my Ryker. The clunk as not stopped but I have gotten more used to it. I have not completely investigated the gear box (and I am totally speculating here) but if the forward and reverse have "dog gears" like an outboard motor they would make a clunk as they actuate.
    I do not have enough miles on my Ryker to say. But my feeling is, it's just the nature of the CVT beast. The drive train is designed to handle the 'clunk'. And it will not get any worse.
    Every machine has it's idiosyncrasies. You either get used to them, or you don't. For example, some people coming from Harley's to the Spyder had a real hard time revving the 998 twin to where it is designed to operate. They lugged the engine in an effort to get the machine to comply with their understanding of how an engine should work, causing all kinds of issues and sometimes damage to components.
    The rider needs to adjust to the machine and how it is engineered to function. This is always the best approach. The operator is the adjustable/adaptive component in this human/machine symbiotic relationship. This is a very important concept if you want to enjoy your ride.
    May 2009
    Connecticut
    How are you enjoying the Ryker - You have not said much after your evaluation?
    Is changing a sway bar a Pita?
    Sea Doo GTI-SE 90 Jet Ski!!
    Johnson, Vermont
    I can't speak for the Ryker but in the snowmobile setup the "reverse clunk" is completely normal. That said. I had the 900 ACE snowmobile out this weekend. I had to use reverse a few times and the clunk is pretty quiet. Nothing to worry about.
    May 2010
    Windber,Pennsylvania
    It will never change. It is literally a tolerance built into the drivetrain. It is more pronounced on their off road sxs's, a little less pronounced on their atv's.
    Sep 2012
    Stetson, Maine
    On my Skidoo 4 Stroke Legend, clunk is there. Also on both of my Outlanders, clunk is there. I believe it is the nature of the beast. Bruce.
    RTS 2011 SM5
    Quote Originally Posted by Sarge707 View Post
    Well, actually a bit embarrassed about my lack of riding time. The weather has been pretty bad here and when it is nice enough to ride, I have not been able to. I need good conditions to give my Ryker a proper workout. I had planned to ride much more than I have and then evaluate the sway bar situation. But with the lack of saddle time I am going ahead with a prototype bar which, on paper, should be right. I will need some experienced test pilots when the time comes.
    I have not attempted to pull the bar yet. I've heard it's a bit different and I've looked at the BRP manual regarding the job. Unfortunately, it just has not been possible to do it yet.
    Believe me. I will post when I have something worthy to say. But so far, I am very impressed with the Ryker.
    Feb 2019
    England
    Hi all ref the clunk when pulling off , I give it a bit more throttle and clunk is gone regards Nico 75
    aka: akspyderman ARtraveler's Avatar
    NW Arkansas
    No Ryker experience....but both my 2011 and 2014 RT's still do it on that initial shift.
    Currently Owned: 2011 RT A&C SE5 (magnesium), 2014 RTS-SE6 (yellow), 2015 Vulcan 900 LTD
    Previously : 2008 GS-SM5 (silver), 2009 RS-SE5 (red), 2010 RT-S Premier Editon #474 (black) Pictures of 2008 and 2009 Spyders are in Alaska Albums 2009 and 2010.
    5 Spyders, 10 years, 145,375 miles
