Results 1 to 13 of 13
    Nov 2018
    N.E. Ohio
    Default What better way to start this off
    With an oil thread. Thinking of using Amsoil in Ryker. Severe gear 75w90 in final, severe gear 75w140 in trans., and not sure in motor. Amsoil has a 0w40 and a 10w40 but the book calls for 5w40 These are Synthetic oils from Amsoil. I’m not a dealer, but have used it in many of my motorcycles. cueman
    Server Admin AnthonyG's Avatar
    mi
    If a fight breaks out, it’s all on you.
    2018 F3 , Red
    The most important thing is to use oil meeting API service specification(s) listed in the maintenance procedures section(s) of the operator's guide.
    Very Active Member Tslepebull's Avatar
    Dec 2018
    East Texas
    I used Mobile-1 Synthetic Gear oil 75W140 in the gearbox of my BMW GS and Mobile-1 75W90 in the final drive. I have some left over so that is what will go into YellaCat but I am sure the Amsol product would be just as good. For engine oil I am going to use this https://www.walmart.com/ip/Chevron-D...84&wpa_bucket=
    It is synthetic in the correct weight and although it is primarily a diesel oil it also carries the SL & SM specifications required for the Ryker (as recommended in the owners manual).
    2019 Ryler Rally , Shock Yellow
    Amsoil MFC 10w-40 will undoubtedly work as well in the Ryker engine as it does in all of the other Spyder/Rotax engines. And I will eventually change out to the other Amsoil lubricants as you mention in your post.
    It is interesting that the Gear Box calls for 5w-40, 10w-50 motor oil or 75w-140 gear oil. This is quite a spread. Not sure which way I'll go on this. But I will probably lean towards the heavier options. I'd rather get better gear life than slightly better fuel mileage.
    Nov 2018
    N.E. Ohio
    Quote Originally Posted by AnthonyG View Post
    See, that wasn't so bad my friends. cueman
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    *checks watch*
    It's early...this thread is only 6 hours old.
    May 2010
    Windber,Pennsylvania
    My experience with oils is... as long as it meets the mfg's specs all is good. I think it is more important that the oil be changed within the correct mileage range. Especially with the BRP off road products I have seen guys who haven't changed their oil regularly end up eating timing chains and guides. With the BRP Spyders with the semi-automatics (which use the oil to shift it) the engine/transmission is especially sensitive.
    Aug 2015
    Crosby,Texas
    For me on the Ryker the 3000 miles service will BRP oil. Then I will look in to Amsoil.
    Nov 2018
    N.E. Ohio
    I believe that will be a very good choice! cueman
    Dec 2018
    Florida
    So, unlike our RT, the Ryker has a separate gear box? I figured this must be the case after seeing posts about a Ryker recall based on no oil in the gearbox....So how what goes in the crankcase? just curious.
    May 2010
    yes, it is separate. In fact, it is the warranty bulletin item mentioned elsewhere in the Ryker section. It runs in 75/90 or 75/140 gear oil, which is very different than the engine oil
    May 2009
    Connecticut
    So the Ryker Does NOT require a Jaso OR Jaso MA2 rating? If this is correct there are tons of Great Synthetics at Good prices.
    Sea Doo GTI-SE 90 Jet Ski!!
