Page 1 of 2 12 LastLast
Results 1 to 25 of 30
    May 2016
    Noblesville, Indiana
    Red face Ok, Let's try this again from a different angle...
    Others have asked about the miles per gallon for the 900. Several respondents said it really didn't matter. My concern is range of this vehicle. At interstate speeds, will the 900 get 200 miles per tank.
    Inquiring minds need to know.
    May 2018
    MN
    5.28 gallons of gas Ryker tank. https://www.spyderlovers.com/forums/...YKER-MPG/page2 one guy said 28 to 29 other guy said hi 20's. So let's say conservatively 28 mpg.
    If we know we get around 28 mpg, 5.28 gallons x 28 mpg = 147.84. I would say no, conservatively speaking.
    If we go eco and say drive like your going to church and get 35 mpg, 5.28 x 35 = 184.80, still be short. Just for giggles if you had 40 MPG: 5.28 x 40 = 211.2.
    Default Don't know...
    Being the same engine as the RT's since 2014 you can use those spec's as a guide maybe add a bit more for the lighter weight. May not be too much info out there on long distance ryding yet but hang in there maybe the warmer weather rykers are venturing out...
    ​2012 RS sm5
    Sep 2013
    Johnson, Vermont
    200 miles to a tankful........I highly doubt it.
    May 2016
    That's not what an inquiring mind wanted to hear.
    With the added data above and figuring the 5.28 is the tank capasity it will not make the 200. Figure it will not hold that much fuel to start with and considering reserve unless you run it till it is bone dry given the mpg's given, although they seem low, your gonna have to stop for fuel or carry a can.... I can average 31 mpg's on my RS and with its 6.6 gal capasity the best I ever got was 186 and it was on the verge of sucking air....I do carry a liter container of fuel just in case...You have no space but there have been those that added a tank in the frunk...
    ​2012 RS sm5
    May 2016
    Well, I guess I'll just have to stop for gas every 2 hours to 2 hours and 15 minutes when traveling on the interstate. Since I'm getting older, maybe that's not a bad thing.
    Aug 2007
    Greeneville, TN
    I seriously doubt we will be getting 200 miles from a tank on the Ryker. But stopping every 2-3 hours in the saddle isn't necessarily a bad idea. It can actually give you more total miles in a day before you've had enough than less stopping along the way. It's not a car where you can go for 400 or 500 miles between pit stops as easily.
    Bossier LoUiSiAna
    & the Ryker not set up to go those distances in 1 trip its more for quick commute trips, in town near gas stations.
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    C'mon Ryker owners. I know you are just having to much fun....but will some of you do an actual computation on what you are getting so far.
    Inquiring minds are wanting to know. Please....
    If we get enough...then we will have the proverbial "ballpark" to go with.
    Jan 2019
    Toowoomba Qld Australia
    Quote Originally Posted by Rob Rodriguez View Post
    Bummer! was hoping to be able to get to my daughter's with fuel to spare even if I went the twisty way!
    2014 ST-S , Cognac
    Nov 2013
    Oro Valley Arizona
    A hundred miles on a Ryker at freeway speeds should be an adventure I would not want to take. Believe me you will want to stop and settle your wind beaten body long before you will need fuel. These are not designed to do
    long distance riding but for sport riding short distances one up.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Default Ryker Gas Mileage
    IMHO the thing that will effect the Rykers gas mileage is the fact that it has a CVT transmission..... From what owners have said to date, is that at 60 mph the Ryker is at 5000 to 5500 RPM's ….. it takes more fuel to operate with higher RPM levels ...remember the 998 engine ………..just sayin …. Mike
    Jan 2019
    And yet in cars the manufacturers tell us they are more economical.
    Point noted Jack. I have never had a bike with any wind protection so will be interesting when I test ride the Spyders and Ryker.
    2014 ST-S , Cognac
    May 2016
    Jack, are you speaking from experience? Have you had one of these machines out on the interstate and is it really that tyring?
    May 2016
    Just saw a video from an owner in New Jersey. He says 35 miles a a gallon in city ryding. Could that mean 40 miles an hour on the highway?
    Sincerely,
    Wishful Thinker.
    Jan 2019
    North Carolina
    Quote Originally Posted by SpyderUSA View Post
    I saw that video too...I think he's speaking completely anecdotally and I am not sure I would trust it.
    Slightly off-topic but I took my Ryker out yesterday for about 15 minutes in 32 degree weather on some local roads (50 MPH). It was pretty windy, but I didn't notice it that much on my chest (no windscreen) , but my hands were completely frozen in just that short amount of time.
    2019 900 Rally Edition , Black w/Yellow Panels
    Active Member bscofield84's Avatar
    Sep 2017
    Aitkin Minnesota
    Worst I got on the interstate - pouring rain, 70mph + pushing water on the interstate with front tires, 126 miles, ran out of gas at top of exist with gas station in site.
    My 14 ST Spyder 6.2 gallon tank I believe.
    Riding in not heavy rain conditions on the interstate, I average about 34 mpg.
    The furthest I have pushed it has been a 185 miles before gas.
    2014 ST SE5 LT , Black Current
    Active Member Michaelscs's Avatar
    Sep 2015
    Cold Spring, MN
    Quote Originally Posted by bscofield84 View Post
    bscofield84, to be clear, you're talking about your Spyder ST not the 900 Ryker this thread is about, correct?
    2020 RT Limited , Petrol Blue
    Nov 2012
    Pueblo Colorado
    Chupacas and bscofields rides being the 990 twins are the closest analogous comparisons at the moment that have some real world miles on them... Until somebody takes a 300 mile trip on the Ryker.
    Then that specific ryder and Ryker combination will have a datapoint for their conditions. The rest is pretty well a SWAG. YMMV..
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
    2015 RT , OEM Black Gloss
    Sep 2017
    Aitkin Minnesota
    Sorry - didn't catch that they were indicating Ryker. I be bad
    May 2010
    Windber,Pennsylvania
    I don't think any of us "new" owners have enough miles on our Rykers to get a real sense of the mileage yet. (darn snow) It takes approx. 2,500 miles on it to get to the point of broken in. Talking to the factory guys that ran the demo trucks, they were seeing about 40 mpg under mixed riding conditions. Assuming we use only 4 1/2 gallons of the available tank that would put it at about 180 miles. Now for me, personally, I have determined that I have a 150 mile butt. It doesn't matter what I am on, after about 2 1/2 hours I am ready to get off and stretch my legs a bit. That's a 30 mile cushion for me and about perfect. I did note that the fuel light comes on pretty early. I could only get about 4 gallons in it after it thinking it was really low on fuel. I will need to do a true "fuel" run where I carry a bit extra and run it out to get the true range.
    Jan 2019
    North Carolina
    Quote Originally Posted by Triumphcycleman View Post
    I'd be thrilled with around 40mpg and 180 mi range. That would get me to nearly North Myrtle Beach! (OK, maybe that's wishful thinking).
    Nov 2018
    N.E. Ohio
    I believe I read in the manual that the reserve light comes on at 1 gallon. Now, as for ryding far distance on a Ryker, I'm going to flash back to my younger days. I had a 1967 Harley FLH and it was my fun to ride bike, go to the store bike, bar hopper bike, work bike, and touring bike. One day I road that bike 10hrs. straight, stopping only for gas and pee break, sometimes not even getting off the bike to get gas on the way to the coast. I guess my point is, What you road seemed to work just fine for whatever you needed it for, when I was young. Now it seems like ever thing has to be specialized to perform a specific duty. I say lets ryde these Rykers where ever, when ever, and for how ever long we want! -----------------or until our health issues make us stop! cueman
    Dec 2018
    KS
    Well said!!
    2019 Rally , Black on black
