Results 1 to 8 of 8
    Nov 2018
    Altamonte Springs, Fl
    Default Air Filter Choices
    I have a 2011 RT. What choices do I have in paper air filters other than BRP? Also where is my fuel filter located? A picture would be nice.
    Durham,Maine
    I got a K&N filter from Ron, have used them in other unit, work great, and they can be cleaned and used for many, many miles! They are a bear to install but worth it in my book!
    2012 RTL , Pearl
    Default Choices, choices
    I also run the K&N filter with the modified air system but had the K&N on the stock airbox as well. They do work much better than the stock filters. Have used them on all my vehicles. There are others like Wix for one and a crossreference check will get you other brands as well. Check with BajaRon here. The fuel filters normally are close to the tank on the right side and can also be obtained at the autoparts stores. There was just posted a thread on them...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    ../../It's one & done deal …… And the K&N filter installs EXACTLY the same as the OEM ….not any more difficult …..Mike
    Nov 2018
    Quote Originally Posted by dg110270 View Post
    Thank you guys. ��
    SoFlo
    Thank you guys. ��
    If you do a little more looking, and ask about the removal of the stock airbox, many people have posted photos about removing the original airbox and going to a different setup. Not sure who has this, but maybe others will reply and direct you.
    FWIW, it has been mentioned before, that while doing the airfilter, you should consider replacing the oem vacuum hoses with silicone vacuum hose bought in bulk and cut to length.
    Also, it seems these earlier fuel injection throttle bodies can benefit from being cleaned while removed.
    Active Member tomand's Avatar
    May 2017
    Boulder City, NV
    k & n works great
    2017 F3T Black
    2016 RT LTD Black - Traded
    2015 Indian Chief Vintage Red
    Nov 2018
    I did the vac hoses recently. Thanks.
