Need to remove to install power plate.....with screws removed it comes loose as it should except for the front bt the black air intake .....as this was part of the air flow/heat fix I wonder if there is another screw.....any in for will be appreciated so I don't break it.
Issue resolved.....bottom of the air scoop is a flat disk...popped off with a screw driver reveals another screw.....
I guess this modification never made it to utube video
IIRC, one of the 2 screws holding that black heat duct thing on where the original little clear OE air wing thingies went does actually go all the way thru & help hold the whole panel in place. So you'll need to carefully lift out the placcy covers on those screw holes, & take the screws out before lifting the whole panel off the bike..... just not sure which of the screws it is! Sorry.
Edit: Dammit, slow typing today. But at least you found the screw!
Removed that hidden screw and the panel came right off...now the next issue which should be a different thread...getting the bolts out of the handle bar to install the power plate.... one came out with difficulty...the other broke off a torx but trying......it's always something.....
