Results 1 to 20 of 20
Thread: Snowblower mods
    Default Snowblower mods
    Two years ago I added rubber extensions on the Paddles that actually throw the snow ….. this gave me another 19 ft. of snow-throwing distance ……… Today I added an LED light in front of the sno-shute above the auger housing ….. Yes It had a small lamp but it didn't give much light because the Chute blocked it ….. now I'll be able to see where I'm going ...…. Mike
    Aug 2007
    Greeneville, TN
    So, blowing snow farther is more important that seeing where you are going?
    ….. this makes no sense ………… I added the LED so I could also see farther ………………. Mike
    Aug 2007
    Greeneville, TN
    Must be me then. Just responding (tongue in cheek) to your statement.
    Nov 2018
    Waynesboro, PA
    Used to be his day job (snow blowing). Now with all the skiing this year he had to add lights to the snow blower because it has become a night job I guess
    2012 RTL , Brown
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by CopperSpyder View Post
    Used to be his day job (snow blowing). Now with all the skiing this year he had to lights to the snow blower because it has become a night job I guess
    Thanks for the info. I knew I must have been missing something. Probably should have just stayed out of it altogether. My bad...
    It's always about throwing it farther.
    I bought the Missus a three-stage Snowblower a couple of season's ago.
    She's throwing snow 70 feet; in places where she could only throw it 15 feet with our old machine.
    Default Great....
    Now you can throw farther and see farther down the road I think Ron was wondering why you started with the throwing further and then seeing where your going and where I did that kind of stuff you were better off seeing where you were going or it would not matter where or how far you blew the snow....
    ​2012 RS sm5
    Very Active Member Bensonoid's Avatar
    May 2014
    Benson, NY
    I added a 30 horse compact tractor with a heated cab to my blower.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    Mar 2011
    oregon
    just put a turbo on it
    2 happy happy spyders
    Jan 2015
    southern WI
    Quote Originally Posted by r1100rider View Post
    Yup, a "cold air intake" will gain you another 20ft for sure. We want video Mike!
    2021 RT Limited
    2016 RTS , Pearl White
    Mar 2015
    forrest above Reno, Nv
    I also added the extensions to the impeller blades as will as a slight RPM increase on the governor. All to often we get S**T for snow at this altitude. Very wet, heavy, easy clogging the chute. With a spray of WD-40 in the chute--- the modified blower just throws is all and considerably further than before.
    Lew L
    2014 RTS , Circuit Yellow
    Mar 2015
    Quote Originally Posted by Mazo EMS2 View Post
    I know your joking------ but cold wet air leads to carb icing on a snow blower. So I added a sheet metal block off plate to the bottom of the " chimney" around the carb. Hasn't iced up since.
    Lew L
    Better yet:
    https://www.youtube.com/watch?v=zvR-eaKUVqU
    Active Member teninospyder's Avatar
    Sep 2014
    tenino, wa
    Hope I never have to worry about that much snow again, Mike. Been there done that !! Have fun...…...REALLY !!
    Ray & Marci
    Tenino, WA
    2014RTL Cognac
    ALWAYS ride 2 up.
    Quote Originally Posted by teninospyder View Post
    To some extant I actually like using the Sno-blower …… When I consider how much effort is needed to do it by hand …. the sno-blower is a remarkable device. By Vermont standards mine is about average 14.5 HP 30 inch wide. How far it throws depends on the water content of the snow. Today it was medium dry ( could almost make a good snowball ) So I was throwing it about 30 ft., which the max distance I need …….later , Mike
    We had the kind of white snot that was wet enough to drip water out of it, when you made a snowball. The Missus was pitching that crap almost 45 feet.
    I ran the "tools of ignorance..."
    Aug 2007
    Greeneville, TN
    I used to run a snow plow (4 yard dump truck. 1/2 load of sand and a plow on the front). But I've never run a snow blower. Sounds like fun! But not a big issue in San Diego, I'm afraid.
