Results 1 to 20 of 20
Thread: Sway Bar
    Aug 2015
    Crosby,Texas
    Default Sway Bar
    Anyone changed the sway bar on the Ryker?
    Default Interesting....🤔
    I know BajaRon was looking into a sway bar for the ryker. Don't know that there is one out there yet... I'm sure there will be an interest in them...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Aug 2015
    Crosby,Texas
    BPR make a HD one. Just can't get the old 1 out.
    Quote Originally Posted by gvcntx View Post
    Gonna need to see the shop manual on this one and don't know if there is one out yet. Sometimes the parts breakdown can help if you go to cheapcycleparts.com you can have a look....
    ​2012 RS sm5
    Active Member NM Wrench's Avatar
    Apr 2014
    Albuquerque, New Mexico
    Whole front end has to come off including the radiator
    14 RT-S , Stock Large brake pedal White Pearl
    Very Active Member Tslepebull's Avatar
    Dec 2018
    East Texas
    I haven/t pushed mine hard enough yet to where I feel the need for the HD sway bar; I'm still getting used to it. What handling characteristics should I look for?
    2019 Ryler Rally , Shock Yellow
    Active Member Michaelscs's Avatar
    Sep 2015
    Cold Spring, MN
    Quote Originally Posted by Tslepebull View Post
    Diving to the outside of a curve in a fast corner. Front end dive to the outside in a swerve.
    2020 RT Limited , Petrol Blue
    Mar 2013
    Quote Originally Posted by Michaelscs View Post
    So Mike,
    Are you going to have the HD sway bar added to Val's?
    Les
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Sep 2015
    Cold Spring, MN
    Quote Originally Posted by PW2013STL View Post
    So Mike,
    Les
    IF we get one, we'll drive it first and determine if it needs one!
    See does look good on one though!
    Active Member AraņaRider's Avatar
    May 2017
    Tampa,fl
    Forgive my ignorance. What’s the sway bar used for?��
    Dec 2018
    East Texas
    The way she is smiling I think the " if " will be when
    Mar 2013
    That she does!
    Nov 2018
    N.E. Ohio
    I have the Rally with the adj. KYB shocks and I adj. to the 4th ring showing on the shock body. This helped a lot, much stiffer and more level in curves. Maybe try this first and see if helps. cueman
    Jun 2011
    Kerrville, Texas, USA
    Quote Originally Posted by AraņaRider View Post
    No forgiveness needed, but I do encourage you to use the search to see all the threads where this is discussed so you get a full range of views.
    In short, on the Spyder, the general experience is that the stock anti-sway bar permits too much sway -- as noted by another poster, the give/play you feel when taking turns at speed.
    I'm not an experienced motorcyclist, but I certainly noticed the issue -- I would get a bit of an uneasy feeling in the pit of my stomach as the bike would pitch or dive before responding positively in a turn. BajaRon makes a more rigid after-market anti-sway bar and links to reduce/eliminate that issue. I had it installed in mine, and immediately noticed the difference. The bike just feels locked and stable in turns the way you want it to feel.
    Regards,
    Bret
    2017 RT-S Orbital Blue
    BajaRon Anti-Sway Bar
    SpyderPops LED Bumpskid, Spyclops II LED, Full View Turn Signals & Belt Guard
    Sena 20S Bluetooth Headsets
    Brake Free Helmet Light
    FOBO Bike for Trike
    Rugged Geek RG1000 Safety Plus Jump Starter/Air Compressor
    Lamonster RAM mount/Techmount TechGripper
    Drink2Go Cup Holders
    UltraGard Half Cover
    2017 RT-S , Orbital Blue
    Dec 2018
    East Texas
    Cueman, how did you adjust to the 4th ring? I have not found a tool to do this.
    Nov 2018
    N.E. Ohio
    I just used my hands and pushed down and turned to show the 4th line. It may help if you jack the front tire off the ground, but I found it easier to just turn the spring as tightening. cueman
    Dec 2018
    East Texas
    Quote Originally Posted by cueman View Post
    Woof, you must have the grip of Hercules. I couldn't get mine to budge. Do you remember the 90 lb. weakling from Boys Life magazine? Stupid broken wrist!
    Jan 2019
    TN
    I know just enough to be dangerous but I have a Miata that I use mainly for auto cross and when I installed anti sway bars on it, I thought I really had something because the body roll was much less pronounced, but the guys with coilovers/shocks and springs AND sway bars were usually faster, if you minimize body roll (car terms I know), you have to match it with proper pre-load and dampening (compression and rebound) to be most effective. That being said, anti sway bars do make a difference, just don't get sucked into a false sense of security when blazing into corners.
    May 2017
    Tampa,fl
    Thank you Bhern !
    Nov 2018
    N.E. Ohio
    I'm sure you can get a shock adj. wrench, but there are so many different sizes and if they don't fit just right, they can slip and do damage to your new bike. So after trying the spanners I had, I figured it would be better to just "suck up the pain" and do it by hand. cueman
