Results 1 to 11 of 11
    Member Waynebang i's Avatar
    Dec 2017
    Hoschton,Ga
    Default Cold weather ride
    I ride a 2013R TS and when I pull it out in cold weather and warm it up the temp gauge comes right to the center of the dial, but is soon as I start down the road it dropped almost all the way to cold. is this normal or is there something wrong with the thermostat or do I need to block off part of the radiator in cold weather
    All the spyders I have had seemed to have "cold weather" issues. For me, the engine temp gauge will always hang low for way beyond what I consider normal.
    I do not warm mine up. Just start em, let em boot up, and drive off.
    I have had the gauge go down when hitting a cold air pocket.
    Dec 2017
    Hoschton,Ga
    Is this bad for the motor or should I not worry about it
    Quote Originally Posted by Waynebang i View Post
    I would say "normal."
    Maybe a few others will chime in and help.
    May 2009
    Connecticut
    My 2012 RT would run 2 bars in cold weather and a few times to one bar.
    Sea Doo GTI-SE 90 Jet Ski!!
    May 2012
    Panama City, FL
    Add me to the normal list. While "warming" up the engine, there is no cool/cold air circulating around the motor or radiator. When you "hit" the road, the cold air circulates around the motor and radiator, the temp guage should drop. Dale
    Default Hard to say....
    as I have seen so many here remove the dial gauges and go with the digital bars on screen. The dial guages seem to be unreliable. Starting up and moving on is not bad for your engine unless you burn rubber and redline the engine out the driveway. Takes 10 or 15 minutes of normal ryding to get to operating temperature I would wait and then to read the guage...
    ​2012 RS sm5
    Dec 2015
    Oakley Utah
    What do you mean by 'cold'?
    2014 RTL Platinum
    Active Member Pallidus Aranea's Avatar
    May 2018
    Eastern Shore of MD
    Cold today was 38F. My 2018 RTL sat in the driveway for about 15 minutes 'warming'. Engine temp gauge moved towards mid-range. Took off and it dropped like a rock. I'd have to say that seems to be a "normal" response. However .... the ambient temp indicator .. lies. It went from 38F to 47F while sitting in the shade of the driveway. Thumbs up on the engine temp gauge - I think it works like it is supposed to.
    Side note - the 1330 loves the cool air.
    Dave
    "Pallidus Aranea"
    (Pale Spider)
    • 2018 CamAm Spyder RT Limited - Pearl White / Chrome
    • 2008 H/D VROD 105th Anniversary Edition (665 of 1200) - Retired
    • 1987 Honda CRB600F - "Hurricane" - Retired
    "Any intelligent fool can make things bigger and more complex… It takes a touch of genius – and a lot of courage to move in the opposite direction." - Albert Einstein
    2018 RT Limited , Pearl White
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Pallidus Aranea View Post
    I don't know if it makes any difference, but I think he has the V-twin
    2014 RTL Platinum
    Active Member Docster's Avatar
    May 2017
    Perry Hall, Md
    Quote Originally Posted by Sarge707 View Post
    Mine as well. If its 20° outside and I'm up on the highway;
    1. I'm glad for heated gear
    2 The heat gauge bars don't get up past 2 bars
    3. Bike runs fine then and gauges show normal temps when not so insanely cold
    2011 Spyder RT-S
    LtCol, USAF Ret
    Proud Patriot Guard Rider
    2011 RT , Yes Blue
