Results 1 to 19 of 19
    Active Member MeudtPG's Avatar
    Aug 2018
    Monroe, WI
    Default Missing Belt Gaurd Install Pictures
    Just installed SPY-149 RT Missing Belt Guard and it turned out good. I had to custom grind the slots in the new guard for it to fit the welded ears on the swing arm but not bad. Just took my time, followed instructions and payed attention to detail. It should pay for itself in no time considering a new belt cost is around $400.00. Hope this helps some folks.
    "BLUE STAR – She shines so brightly"
    2018 SPYDER RT LTD SE6 BLUE/CHROME
    2018 RTL , Large Brake Pedal (cut 1/3 off). Oxford Blue/Chrome
    Northern Kalifornia
    I'm guessing you did not remove the swing arm to do the welding. What did you use to repaint the weld job?
    Aug 2018
    Monroe, WI
    I did not do any welding. What you see is OEM from the factory. The factory weld beads around the tabs vary in size so I had to make the new missing guard fit the welds. No painting.
    Northern Kalifornia
    Got it. Thanks.
    Jul 2018
    Long Island NY
    I think the MBG should be one of the first things we add to new Spyders. Too many rocks/tar pebbles on the roads, that can eat up a belt. I installed one the night before I went on vacation. The first highway I turned on was being repaved and there was millions of those sticky tar pebbles. When I got to my destination I had to use my knife to remove those pebbles from my MBG and a few other places. Without installing that, I’m sure I would of had belt problems. Cheap, easy install and tremendous piece of mind. Good job MeudtPG!
    2018 RT Limited , Metallic Champagne
    Aug 2018
    north wis
    MBG is available where? Sounds like a good idea!
    Aug 2018
    Monroe, WI
    Quote Originally Posted by woods View Post
    Just click on the SPYDERPOPS above sponsor or click this link https://spyderpops.com/belt-guard-fo...330-cc-engine/
    Double check application for your year.
    Jul 2018
    Long Island NY
    Hi Woods. It’s a great idea!
    When I first purchased my Spyder I prioritized the aftermarket parts I wanted to buy, and “Protection” was at the top of my category list.
    MBG is easy to install; just watch the videos first, and be extremely careful w placement after you activate the adhesive. Once it’s stuck on, it stays on. lol. And that’s a good thing. Belts are about $300 (not to mention you’re unable to ride while being repaired) so for $45, great use of $$. I highly recommend it, when I first hit those tar rocks my heart jumped, then I remembered I installed MGB the night before. My vacation would of been over only 10 minutes into my trip if I hadn’t done that.
    Good luck.
    Jarred.
    Aug 2013
    SF Bay Area
    I installed one last year and thought I had it right so it wouldn't run the belt but I'm, guessing that vibration happens and the lowest tip of the MBG got rubbed away but it sill works and what's also weird is the belt vibration is gone.
    2021 F3 Ltd , Magna Red
    Member 311tomcat's Avatar
    Feb 2017
    Poinciana, FL
    Nice job on the belt guard installation.
    Did you grind the slots, using a Dremel?
    Aug 2018
    north wis
    Thanks for the info! I guess the warmer weather wrenching list just got a little longer!
    Aug 2013
    SF Bay Area
    Quote Originally Posted by 311tomcat View Post
    All I did was clean the area where it was going to stick on, primed it and carefully placed it so it ended up between the tire and belt. The MBG already had cutouts for the area. This is the one I got. http://www.lamonstergarage.com/can-a...ster-approved/
    Mar 2015
    forrest above Reno, Nv
    Default Farkles
    The first farkel on my was the MBG ( missing belt guard). followed by the bump skid and high mount brake light. Latest farkel is an ECU Stage 1 up grade. So many in between
    2014 RTS , Circuit Yellow
    Jul 2010
    Arkadelphia, Arkansas
    That's another POPS ORIGINAL!
    Jan 2019
    Toowoomba Qld Australia
    Forgive my ignorance. So the F3 doesn't need a belt guard (only saw the RT listed)? Has one from the factory? Thanks Glenn
    2014 ST-S , Cognac
    Quote Originally Posted by glennm View Post
    SpyderPops has one for the F3 Touring and Limited. The other F3s have a tube swing arm and there's no guard made for them that I know of.
    Sep 2018
    Caledonia,Ontario,Canada
    Love my Smoothspyder belt tensioner/belt guard. Well engineered for my 2013 ST-S 998. Easy install and tensioning, now just waiting for the weather to cooperate!
    Jan 2019
    Thanks Idaho. Tossing up between A F3 S and Ryker. Gravel roads (including our driveway) and a council that likes to put tar down then sprinkle gravel on top in my area.
    2014 ST-S , Cognac
    If that is a major issue I'd go with the Ryker!
