Results 1 to 14 of 14
Thread: seat release
    Jun 2014
    magnolia,ohio
    Default seat release
    I can no longer turn my key to release the seat so that I can put fuel in it. Is there a way to open it?
    Mar 2013
    Quote Originally Posted by kdr View Post
    You should be able to pull the right hand side of the seat away from the body to allow you to slide a long flat blade screwdriver between the seat and body to push the release lever. Once open you can attach a wire to the release arm and run it past the seat so that you can open it as needed.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Nov 2018
    St Pete Beach
    Have you tried pushing down on the front of the seat as you turn key.....might help release it.
    2018 RT , Asphalt Grey
    May 2014
    Benson, NY
    Here's a picture of what you're dealing with in there and an option to cure the problem.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    Nov 2013
    Oro Valley Arizona
    Clean with WD-40 and check adjustment nut on seat post that enters latch. Then lithium white grease on post and latch that post goes into. Do the same on Frunk latch. This will prevent a lot of head aches down the road.
    When these are not lubed they begin to hang up and stretch the cables slightly.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Good advise above as to how to get it open and fix the problem. There are several backups you can search out and some simply removed the pin as they did not feel the need for a locking seat.
    https://www.spyderlovers.com/forums/...t=seat+release
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    ...……….However RE-MOVING the pin is IMHO not a good solution. Yes it's primary purpose is to secure the seat …. But I've seen what happens AFTER it's removed ….the seat can and will slide forward and the seat sides will rub the paint below the glove box. When you move the seat back there will be serious SCUFF marks. The bolt at the rear of the seat pan does not prevent it from sliding forward …..That PIN does that ….. just sayin …. Mike
    Jun 2014
    magnolia,ohio
    Thanks I will give that a try.
    May 2018
    Chateauguay, Qc, Canada
    My seat went down and latched yesterday on my RT and I can't open it either so this post is very timely. I urgently want to get it open as I need to reconnect my battery maintainer. I have some questions on what I have read.
    KDR, what model of Spyder you got there with the stuck seat?
    PW2013STL, what model of bike you got where you push with a screwdriver? Are you pushing from the back? The photos of the seat latch seem to indicate you need to pull forward to unlock the seat.
    TIA for your help
    Eckhard.
    2011 RT Ltd. , Pearl White
    May 2018
    Quote Originally Posted by Eckhard View Post
    TIA for your help
    Eckhard.
    Got it fixed. Hardest part was finding a long screwdriver.
    …….Now safety wire it and use the wire instead of your key …… I did years ago ……. Mike
    May 2018
    I'll save that job for the spring.
    It is hovering around 0 deg and we are waiting for a dump of snow. I've put a styrofoam block under the seat to prevent it from latching.
    Jul 2018
    Columbia,Tennessee
    Our latch done the same thing. So when I did get it open I just took a zip tie and tied it open. The pin still works to keep the seat still. But now I just get off and raise the seat and pump gas and go.
    Jun 2014
    magnolia,ohio
    I have 2013 Rt I tried to open it with a long screw driver but evidently I am not pushing on the correct part or area.
