Results 26 to 50 of 56
  1. #26
    Active Member Michaelscs's Avatar
    Sep 2015
    Cold Spring, MN
    Quote Originally Posted by Lamonster View Post
    The stock peg is longer than most. We can add pegs to our adapter but it won't be any longer than stock.
    Not looking for longer. Looking for wider(front to back) with perhaps rubber grips.
    2020 RT Limited , Petrol Blue
  2. #27
    Springfield, MO
    Quote Originally Posted by Michaelscs View Post
    That we will be able to do. Stay tuned.
  3. #28
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    Maybe something like a small ping pong paddle shape? Something that would allow it to tilt up and clear the brake lever while being adjusted.
  4. #29
    Active Member Ryker900's Avatar
    Jan 2019
    Blacklick, Ohio
    Looking forward to getting these. The picture looks like the brake pedal is pretty close to the board. Does it clear the board when the brake is applied?
    2021 RTL , Red
  5. #30
    Jan 2019
    Blacklick, Ohio
    Default Ryker Floorboards
    Lamont:I like these floorboards. When will they be available?
    2021 RTL , Red
  6. #31
    Jan 2019
    Blacklick, Ohio
    We have the mounts done and hope to get some testing in this week. They turned out really nice and fit the look of the bike well.
    I'd like to get these, but it looks like they are really close to the brake pedal. Does the brake pedal clear them when pressed down?
    2021 RTL , Red
  7. #32
    Quote Originally Posted by Ryker900 View Post
    You might want to give him a while on that one, Ryker900 - he does have other stuff on his plate & I suspect he's not on the boards at the moment. So hang tight, he'll get them out as soon as he can!
  8. #33
    Jan 2019
    Blacklick, Ohio
    No problem. I can wait. It's still too cold here for me to ride anyway. I can't afford heated riding gear.
    2021 RTL , Red
  9. #34
    Springfield, MO
    The floorboard adapters should be heading to the anodizer this week. I hope to have product in the store next week. As far as the break goes it is adjustable.
    Took a little spin on it this weekend. https://www.facebook.com/LadyLamonst...3391890218152/
  10. #35
    Jan 2019
    Blacklick, Ohio
    I see you have a backrest on it in the video, will that be available too? How about a top case with a backrest? I'm 75 years old and bought a Ryker 900 ACE. Haven't been able to ride it much since it's so cold here in Columbus,Ohio. Can't afford the heated gear.
    2021 RTL , Red
  11. #36
    Springfield, MO
    Yes we will have a backrest and it will work with a topcase. I'm waiting on one part to finish that.
  12. #37
    May 2012
    Panama City, FL
    The floorboards look great on and off of the Ryker. Great job, hope your health continues to improve. Dale
  13. #38
    Active Member wolphspyder's Avatar
    May 2013
    Elgin, Texas
    Looks like another great addition by Lamont......keep up the good ideas,my friend .
    " My Serenity "......2017 Spyder F3T....Silver Gray in color,Red dragon on Celtic cross on frunk,Blade wheels,Spyderpops bumpskid,LED headlights and foglights,Lamonster heim joints,Lamonster powerpoint,F3 Spyder cuff, Lidlocks helmet lock,Lamonster air pack,Ron-jon sway bar,Sara Clark painted thin blue line and Sheriffs badge, Spyderpops LED strobe brake and rear turn signal lights, Lamonster gas cap, bluetooth.
    2017 F3T , silver
  14. #39
    Jul 2010
    Las Vegas, NV
    Very cool! I think those look great! Keep on imagineering - dream up cool stuff and make it!
    Joe Meyer
  15. #40
    Active Member Wijames's Avatar
    Sep 2018
    Milwaukee
    Noticed the LEDs in the hood on the video. Looks good! I would buy a set.
    2019 Ryker Rally , Black and blue
  16. #41
    Jan 2019
    Blacklick, Ohio
    Default Backrest
    That looks great, but I don't think it will work with the top case I got from Can Am.The Linq Top Case (It sits right up against your back with no place to fit a backrest, so pretty much it is the backrest with no padding)Real Ryker in driveway Jan. 3.jpg Do you have another top case available? Thanks
    2021 RTL , Red
  17. #42
    Jan 2019
    Blacklick, Ohio
    I would gladly give up my Linq Top Case for a backrest, it doesn't have much room inside it anyway. I'd like a better top case and one that locks and holds my helmet anyway.Thanks for all your great inventions.
    2021 RTL , Red
  18. #43
    Jan 2019
    Blacklick, Ohio
    Do you think this top case would fit behind the backrest: https://www.revzilla.com/motorcycle/shad-sh29-top-case
    2021 RTL , Red
  19. #44
    Springfield, MO
    This is what we are working on mounting on the Ryker. This is the expandable top case.
    48404711_1169501466543282_9109314309816582144_n.jpg48967466_1169501469876615_1396237423469395968_n.jpg
  20. #45
    Jan 2019
    Blacklick, Ohio
    Is that a Shad? I'm looking at one that is much cheaper. That one is too expensive for me. If that Shad will work I'm guessing they all should. It has a universal mounting plate right?Shad top case.jpg This is what I'm thinking. It has a backrest pad attached. It's made for a passenger.
    2021 RTL , Red
  21. #46
    Jan 2018
    NH
    hmmm...you know what would be cool? A storage case that mounts on the back of the Rykers large passenger back rest so it could be used when the back rest is tilted down for single ride usage or when there is also a passenger on it.
    The door seam would probably need to be at a 45 degree angle so when its in the single ride mode the angle goes down towards the rider and when tilted up for a passenger the door seam would them be tilting down away from the rider.
  22. #47
    Jan 2019
    Blacklick, Ohio
    Are these the floorboards that you are going to put on the Ryker: http://www.lamonstergarage.com/can-a...cle-lamonster/ Just wondering so I can save for the price of them.Thanks
    2021 RTL , Red
  23. #48
    Sep 2018
    Milwaukee
    How is the top case coming along?
  24. #49
    Active Member bignose13's Avatar
    Nov 2010
    Park City Utah
    Am i blind? where is the link to the floorboards
    Ryker Rally Edition...Sooooon
  25. #50
    Quote Originally Posted by bignose13 View Post
    It's there, you just hafta go back to the beginning & follow the thread.
    Lamont posted pics in page 1, post #1 & there's the video link in post #3; there's more again in post #17 & a link to facebook showing a ryde with the floorboards fitted on page 2 post #34 as well as Ryker900's link to the Spyder version in post #47 above.
    Here that last one is again: http://www.lamonstergarage.com/can-a...cle-lamonster/
    Just remember that you'll need the F3 & Ryker bracket kit as well.
