Results 1 to 11 of 11
    Very Active Member al0vely's Avatar
    Apr 2016
    Indiana
    Default I don't see any Vendors
    I no longer see the sponsoring vendors on the main SL page.
    Love my Spyders
    2016 F3L Steel Black purchased 7/16/2016 Sold 3/11/2023 (22,500 mi)
    2014 RTS Circuit Yellow purchased 3/2/2018
    2020 RTL Petrol Blue purchased 1/27/2023
    Girls on Spyders #3195
    No more 2 wheels
    2020 RTL , Lamonster floor board riser Petrol Blue
    Jul 2015
    Dorr, michigan
    I just checked, and they are all showing up on the home page when I go there. Did you try refreshing your page?
    2020 RT Limited , Petrol Blue
    Dec 2013
    Is that all you are seeing of the Home Page? If so, you appear to be missing more than just the vendors?!
    Have you changed anything lately? Added or turned on a pop-up blocker or installed a different firewall? I can still see all the vendors on both my devices, and so far, no-one else has mentioned they are missing them, so at this stage I'd hafta guess at it being a problem on your machine/device. Others may have more info/advice as the day progresses. Sorry I can't be of more help right now!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Nov 2012
    North Las Vegas, NV
    Turn off your Ad Blocker. I had the same problem.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Sep 2017
    INDIANA, USA
    Default Vendors
    I see them on the 'HOME' page.
    ENJOY YOUR LIFE WITH A SPYDER
    Vermont
    Default Vendors on the "Home Page"
    I also see the list of Venders on the "Homepage" and everything else on the "Home Page".
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Active Member spydernatic's Avatar
    Aug 2012
    Covington Georgia USA
    Yup did that turned off my AD blocker and now I can see all the Vendors ...Thank you
    2017 RT Limited
    2017 RT Limited , White
    Default After a while....
    I see what you see but after a bit they seem to load up... will have to sign off and on and see if it clears or figure out the add blocker thing....
    ​2012 RS sm5
    Apr 2016
    Indiana
    That problem was on my work computer and I didn't get another chance to go to the SL site. I see all the vendors at home if I use firefox - my chrome browser has been broken for a while on SL. I also use Chrome at work and will try the pop up blocker tomorrow.
    Love my Spyders
    No more 2 wheels
    Active Member Spyderjuice's Avatar
    Aug 2008
    High Point, North Carolina
    What he said. Same problem and ad blocker was problem.
    Happy owner of 2014 White RTS - SE6
    Oct 2016
    Faribault, MN
    Yep Chrome recently had an update that added stronger Ad-blocking which can be turned off for spyderlovers.com and you'll see the ads
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
