Results 1 to 14 of 14
    Nov 2018
    Williamsburg, Va.
    Thumbs up Touring windscreen for st
    Curious if anyone has found a windscreen that is wide at the base to block some of the side air. I can barely hear the radio. The height seems ok. I saw one at ebay -28.5 inches at the base and available in three heights. The issue is it doesn't give the manufacture and no info on mounting and if it is pre-drilled to fit the st brackets.
    All info is appreciated
    Active Member bscofield84's Avatar
    Aitkin Minnesota
    I've been looking for something wider also. Let us know if you find something - will do the same.
    2014 ST SE5 LT , Black Current
    Jun 2017
    Crossville TN
    We got ours from Jurock was taller and wider, I got the taller one for the boss
    Dave
    2013 RT Limited
    Lamonster FBB with larger gripper pegs
    Value Accessories dah mount
    Custom Dynamics High Mount brake light
    BRP passenger arm rests
    Nov 2018
    Williamsburg, Va.
    Just found it Cal Science 28.5 wide at the bottom and various heights
    Bossier LoUiSiAna
    Headsets also fix the hearing issue just another option to investigate
    Nov 2018
    Williamsburg, Va.
    Yes indeed. Also, download your music onto a chip--insert chip into gps ( there is a slot) and play through the gps and speakers under options music continuous and the sound is very clear.
    Nov 2018
    Williamsburg, Va.
    Installed the Cal Scientific windscreen. Very straight forward and easy. I opted to get some black torx bolts (longer than the factory bolts) in lieu of the provided bolts to maintain an original look IMOP.
    I now a essentially wind free driving pocket. Can actually hear the radio and GPS. Optics appear very clear. At mind point I can see over the windscreen. The factory cut out (vent) is very nicely done and placed perfectly.
    Highly recommended.
    Jan 2018
    SW washington
    Delsurfin,
    How tall are you; what height windshield did you choose and what position is the windshield in it's adjustment range?
    Nov 2018
    Williamsburg, Va.
    I am six 6 feet tall. windscreen is 28.5 wide by 23.5 tall. I ride at the mid point setting and its right about at the top of my nose. I can see over and it blocks the wind (at the shoulders too). Optics are very good.
    Jan 2018
    SW washington
    Thanks for the additional information. I'm currently using the CAM touring screen with a MRA touring wing on top. In the low setting from the center it measures 25 3/4" but is only 22 1/4" wide at the bottom and 15 1/2" at the top. The additional width at the bottom must really be effective. I'm just over 6' so the coverage should be equivalent to your experience. Have you modified the screen adjustment mechanism? I haven't yet and it won't stay in the mid or upper adjustment.
    Nov 2018
    Williamsburg, Va.
    I have not done any adjustments to the raising mechanism--hope I don't have to.
    Screen does not vibrate
    Aug 2018
    NH
    I have 2013 ST.... will larger windshield OEM 705005673 fit?
    Jan 2018
    SW washington
    used one on EBay for $60: https://www.ebay.com/b/Windshields-f...67/bn_20713856 shows that the OEM #705005673 is for the ST.
    Active Member spyderfish's Avatar
    Jun 2014
    West Bloomfield, MI
    Have the CalSci extra wide and tall. Holes were drilled correctly, install was quite easy.
    Makes a big difference, no head buffeting. Hands still exposed, using heated gloves.
    2021 RTL SE6 - Marsala Red Blackout
    BajaRon Nosway Bar
    Front CentraMatic Balancers
    Value Accessories HandleBar Riser
    Brake LED Flasher
    Customized SmoothSpyder Tensioner
    Phone Phang
    Smart Mount Backrest
    LaMonster Mirror Locks
    Hopnel Frunk Bag
    Ultraguard Cover
