Results 1 to 8 of 8
    Feb 2016
    France
    Lightbulb RT 1330 Spark plug change
    HELP ANYONE:
    I'm trying to change the spark plugs on my 2014 1330 RT.
    I've got as far as trying to remove the primary air box (front one), I've undone the 2 bolts at the back and the 2 at the front through the aluminium bar, flipped off all hoses that I can see, lifted headlamp cable away,made sure all cables and wires are not obstructing, now I should be able to wiggle the air box out of the left side of the frame, it's very loose but it won't come out. Do I really have to remove the Frunk?, it looks like the airbox should now ease out of it's space but I can't see what's holding it, Do I need to remove headlamps and frame, can't see what else to remove as I have a clear sight all round of the airbox, once the airbox is out the rest looks easy and convential.
    Sorry can't post any photos of how far I've got, something screwy with my computer.
    Any help would be grateful
    Thanks in advance
    Alex
    2014 RT Std
    Floor and Highway Boards
    50$ GPS connected to oem loom
    Trunk & Frunk Liners and lights
    Frunk and dashboard power outlets
    Front supension LEDS
    Cup holders
    Glovebox light
    Turn signal LEDs in mirrors
    12 volt coffee maker
    Passenger hangrip muffs
    Ignition lock light
    Windscreen wiper/ baguette holder
    If I wasn't so cleverI wouldn't need to be so good looking.
    2014 RT , Black
    May 2009
    Connecticut
    https://youtu.be/EXX5AQtdHzo
    I dug this up and Bob gives some good tips that Might help?
    Sea Doo GTI-SE 90 Jet Ski!!
    Sep 2018
    greensburg,pa
    2018 RT-L , Blue
    Quote Originally Posted by agedbikeman View Post
    You have to pull it out the right side, not left. Maybe my experience and pics will help. https://www.spyderlovers.com/forums/...angeout-Part-1
    Quote Originally Posted by bluewoo View Post
    Since the OP said He has a …..2014 RT …. this video is useless …… Mike
    Sep 2018
    greensburg,pa
    THANKS!
    2018 RT-L , Blue
    Mar 2013
    You stated that you removed the bolts to the aluminum bar, but did you remove the bar? I know I had to.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Aug 2012
    Central Coast, CA
    HELP ANYONE:
    Thanks in advance
    Alex
    I just saw this, so sorry if it's too late. The airbox separates into 2 pieces. You have to reach inside and then separate the two halves. It's been about 2 years since I did mine, so I don't remember the exact details of how it's connected. I want to say it was snapped together with a retainer. It was self evident once you looked inside the air box.
    2020 RTL SE6
