Results 1 to 4 of 4
Thread: Wild hog
    Aug 2018
    meridian ID.
    Default Wild hog
    What is the belt tension for a 08 can am 990? Anybody know the torque setting for the front sprocket bolt.? Last, how is the 660 loctite applied to the gear & or bolt. Thanks guys &gals
    Default Little checking.....
    According to the manual....
    front sprocket bolt is 81 ft lbs 2008-2009 later models 92 ft lbs
    Tension 450N +/- 150N ( we use the krickit and run 160 to 200 lbs, I keep it on the low side)
    Thread lock on the bolt threads only
    If you remove the front sprocket bolt it is recommended you install a new bolt (if ordered from BRP or Cheapcycleparts.com it will come with the thread lock already applied.
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Quote Originally Posted by wild hog View Post
    I kept my 08 GS on the loose side about 165lbs ….measured ON THE GROUND …. I never had any issues and I didn't feel any vibes ….. Mike
    Aug 2018
    meridian ID.
    Thanks a bunch . what a great site. Thanks again folks.
