Results 1 to 14 of 14
Thread: Rear Luggage
    Active Member BigBlock's Avatar
    Jul 2018
    British Columbia, Canada
    Default Rear Luggage
    I just purchase a trunk rack for my Spyder Rt and was curious what people are using for luggage on this rack. What size, brand etc...
    Was looking at this-Nelson-Rigg Deluxe Rear Rack Bag - GWR-1200 35160166.jpg
    2018 RT Limited , Champagne
    Quote Originally Posted by BigBlock View Post
    The rear trunk has a max recommended weight load of 20 lbs ( I have put quite a bit more )…. Be careful the load on the rack + what's in the trunk doesn't go to far above BRP's recommendation ………………. Mike
    Dec 2015
    Oakley Utah
    I think most folks who have this rack, including my wife, just strap miscellaneous items to it when they don't fit in the side bags or frunk. I haven't heard about anyone using specific motorcycle luggage on the rack, but it makes sense. As Mike says, try not to exceed 20# (including the rack), or you will exceed the OEM specs AND make it very difficult to open the trunk!
    2014 RTL Platinum
    Feb 2012
    Spring City,Utah
    I use the Rally Pack. I has a large pack and a smaller roll pack and they can be used alone or together. Both have straps that will hold the securely to the bike. I also have trunk pack(don't know what the real name is) That is made by Hopnel for Gold wings for years. I have had this one since the mid 1990s and it still works well. I put my rain gear in it when I am traveling alone. It is a Brown color and matches my 2012 well. Hopnel used to make them in all sorts of colors but I think they only come in black now. They come with a rain cover. They also have 2 pockets in the front that are nice for putting sunglasses or sunscreen or other small things in.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Jul 2018
    Thanks for all your replies. I will probably get a med sized luggage/bag to use for light items such as rain gear, extra gloves etc... I will definitely watch out not to exceed the 20lb weight load.
    Sep 2015
    New London. Texas
    I use the nelson-Rigg bag on a rear rack and love it.
    Sep 2012
    Stetson, Maine
    We use a small duffel bag.
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Nov 2017
    San Francisco Bay area
    Question. Since I ride solo on an RT at the moment, is anything made to go in the passenger seat?
    2015 Pearl White RTL
    Baja Ron Sway Bar
    Russell Day Long Seat
    Strobe Brake Light
    2015 RTL , Yes Pearl White
    Vermont
    Quote Originally Posted by LeftCoast View Post
    I also own an RT( 2014RTS-SE6) and I also ride solo. What I do is I use 2 duffle bags ( medium size) stack them on top of each other, and use buggies cords to strap them down. I hook the buggies cords to passenger hand grips. These do not move. When I travel with the duffle bags the routes that I taken have some very sharp corners. ( like the tail of the dragon corners). But I am in Vermont.
    Sorry no pictures, at this time, spyder is hibernation.
    Hope this helps.
    I don't use any rear racks.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Nov 2017
    Hope this helps.
    Deanna
    Thanks Deanna, that’s great info. Like you I don’t want to put on a rack
    Baja Ron Sway Bar
    Strobe Brake Light
    Active Member Spyderjuice's Avatar
    Aug 2008
    High Point, North Carolina
    Check out "Lamonster Garage" on the home page banner. He has bags for the rack as well as for the back seat. Several choices. Fit well and I like them.
    Happy owner of 2014 White RTS - SE6
    Aug 2009
    Cedar Park, TX
    We got a Coleman waterproof (?) bag that Is compressible and kind of clear primarily to keep rain gear or things we might need in a hurry.
    Active Member Scotts8826's Avatar
    Jun 2014
    Kansas
    I have an Iron Rider bag I use for my overnight bag on my rear rack. Overall I'm satisfied but I would look closer at a rain proof bag. Mine came with a cover but in a heavy rain my clothes were still wet.
    May 2018
    millsboro,delaware
    I have had a Kurayakn bag on my GW and the same bag fits the rack on the RT perfect.Thus bag has 2 side compartments that you can get to easy and it has a rain fly that stores in a built in pouch.I use a small scale to check the loaded weight and usually keep it under 18 lbs.
    : 2017 RTL ORBITAL BLUE
