belt or chain
Can anyone tell me what they are using to transfer power from the driven clutch to the driveshaft.
Ryker has CVT, which is variable belt for speed, that goes right to output shaft, to final shaft drive to wheel. NO BELT OR CHAIN
" belt or chain"
Depends how naughty you are
INSIDE OF GEARBOX
From the driven clutch of the CVT, it goes into the gearbox, which has forward and reverse mechanisms. Inside this gearbox are actually two chains which move between the gear shafts and, ultimately, to the output shaft and out thru the driveshaft. It reminds me a little of a transfer case in a truck so it should be ultra reliable
SpyderLovers Sponsor
I think the 'Transfer Case' analogy is a good one regarding the gear box. The CVT transmissions have been around for a long time. They work well in many applications. Not so good in others. Time will tell with the Ryker. But I think it is a good fit for this vehicle.
You can hover your mouse pointer over each picture to get a bigger view. But the simple answer to the OP's question is. 2 Chains and a Belt go between the engine and the shaft drive.
CVT (Input from Engine Crankshaft - Output to Gear Drive)
Part #21 is a V-Belt
Here is the CVT in its housing
Gear Drive (Input from CVT - Output to Shaft Drive)
Part #4 - is a Hyvo Chain
Part #2 - is a Chain
Here is the Gear Drive in its housing
This is basically how the snowmobile is set up. The CVT transfers power to the chain case which is just a case with 2 gears and a chain that spins the axle. On the sleds its recommended you adjust the chain tension after 500 miles (which is super easy) and then its good to go. This setup is bullet proof reliable on sleds and the chain sees a fair amount of force when you jump a snowmobile and the track comes back in contact with the ground. The Ryker will never see this type of action.
