Results 1 to 7 of 7
Thread: belt or chain
    Aug 2009
    Cherokee,Iowa
    Default belt or chain
    Can anyone tell me what they are using to transfer power from the driven clutch to the driveshaft.
    Active Member Woodaddict's Avatar
    Mar 2017
    Salisbury,NC
    Ryker has CVT, which is variable belt for speed, that goes right to output shaft, to final shaft drive to wheel. NO BELT OR CHAIN
    Very Active Member Rogue Hawk's Avatar
    Apr 2015
    Chicago
    " belt or chain"
    Depends how naughty you are
    Velvet Hammer akspyderman's Avatar
    Chugiak, Alaska
    The RT's and F3's use a belt drive. The new Ryker is a shafty. There are no chains on the Spyder/Ryker line ups.
    Currently Owned: 2011 RT A&C SE5 (magnesium), 2014 RTS-SE6 (yellow), 2015 Vulcan 900 LTD
    Previously : 2008 GS-SM5 (silver), 2009 RS-SE5 (red), 2010 RT-S Premier Editon #474 (black) Pictures of 2008 and 2009 Spyders are in Alaska Albums 2009 and 2010.
    5 Spyders, 10 years, 145,375 miles
    May 2010
    Windber,Pennsylvania
    Default INSIDE OF GEARBOX
    From the driven clutch of the CVT, it goes into the gearbox, which has forward and reverse mechanisms. Inside this gearbox are actually two chains which move between the gear shafts and, ultimately, to the output shaft and out thru the driveshaft. It reminds me a little of a transfer case in a truck so it should be ultra reliable
    I think the 'Transfer Case' analogy is a good one regarding the gear box. The CVT transmissions have been around for a long time. They work well in many applications. Not so good in others. Time will tell with the Ryker. But I think it is a good fit for this vehicle.
    You can hover your mouse pointer over each picture to get a bigger view. But the simple answer to the OP's question is. 2 Chains and a Belt go between the engine and the shaft drive.
    CVT (Input from Engine Crankshaft - Output to Gear Drive)
    Part #21 is a V-Belt
    Here is the CVT in its housing
    Gear Drive (Input from CVT - Output to Shaft Drive)
    Part #4 - is a Hyvo Chain
    Part #2 - is a Chain
    Here is the Gear Drive in its housing
    Johnson, Vermont
    This is basically how the snowmobile is set up. The CVT transfers power to the chain case which is just a case with 2 gears and a chain that spins the axle. On the sleds its recommended you adjust the chain tension after 500 miles (which is super easy) and then its good to go. This setup is bullet proof reliable on sleds and the chain sees a fair amount of force when you jump a snowmobile and the track comes back in contact with the ground. The Ryker will never see this type of action.
