Results 1 to 16 of 16
Thread: heated grips?
    Very Active Member Rogue Hawk's Avatar
    Apr 2015
    Chicago
    Default heated grips?
    They are not an option right now. I wonder if there is a third party brand I can use. Maybe Oxford? BTW, I hated the ones on the F3, they never got hot enough and the button was so tiny I could not toggle it with a gloved hand.
    2019 Rally , Black
    Very Active Member Tslepebull's Avatar
    Dec 2018
    East Texas
    I hope to see something in the aftermarket. Heated grips are so cozy
    2019 Ryler Rally , Shock Yellow
    Active Member Spider-man's Avatar
    Mar 2017
    San Antonio
    I got these. Pretty easy to install, and they get hot as he**!
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    May 2009
    Connecticut
    I researched the Oxford "Premium " Updated grips and was going to put them on the Ryker but decided just to get another battery harness and use my Warm and Safe Glove liners that I use on the F3. The liners are so much more comfortable than gripping to feel heat. Minus feature-you attach the wire?
    Sea Doo GTI-SE 90 Jet Ski!!
    I can't comment on the Oxford brand …… but I have seen many others - that have multi- heat levels, check what's available on E-bay …… Mike
    Apr 2015
    Chicago
    I do want one where I can change the temperature. Are the Ryker bars the same size as on two wheelers?
    2019 Rally , Black
    May 2010
    Windber,Pennsylvania
    YEP, 1 7/8"
    May 2017
    Mesa, Arid-Zone-A
    I don't remember the brand but we had heated grips installed on my wife's Goldwing that had a rotating reastat. She had infinate control over heat output. I do remember they were made by a common motorcycle aftermarket company so should not be too hard to find...... Jim
    Semper Fi
    May 2009
    Connecticut
    https://youtu.be/aX4mV8XyPI8
    These are well rated and have 5 Percentage settings on the controller. Won't break the bank either-
    Aug 2016
    Pembroke, Massachusetts
    Quote Originally Posted by Rogue Hawk View Post
    I installed oxford on my Honda Nc700x. It was easy and has 5 levels of heat. Warmer then the ones on my F3L.
    Bob
    Apr 2015
    Chicago
    Quote Originally Posted by Triumphcycleman View Post
    YEP, 1 7/8"
    Good, the F3 has big chunky none standard bars. So on the Ryker, I should be able to install a 'standard' kit meant for a transitional bike. The only other concern I have is the bar end mirrors. I don't know if they can be reattached to the third party grips. I may have to get some 'rabbit ears' rear view mirrors. Thoughts?
    2019 Rally , Black
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    Has the smaller battery size on the Ryker been considered when looking at heated grips? Or will it come into play...since the heated grips will require a certain amount of amperage to run ?
    May 2009
    Connecticut
    https://youtu.be/4MNBKrWMSSQ
    This shows the end bars loosening- Not sure if the grips would work or Not. BRP does sell the Sport Grips so you must be able to change them?
    Apr 2015
    Chicago
    Quote Originally Posted by Sarge707 View Post
    I guess I will have to wait and see. The bunny ears is always an option since the ryker has a normal sized bar.
    Here is one that fits the 1 7/8 bar. I may try this.
    https://www.revzilla.com/motorcycle/...e-heated-grips
    2019 Rally , Black
    Jun 2011
    Alamogordo, NM
    Has nothing to do with Battery Size, but everything to do with Alternator out put and system power draw. Doubt if heated grips would be the slightest problem at all.
    Dean O
    Gran Pa Hoon
    Founder San Jose BMW
    Alamogordo, NM
    '20 Spyder F3 L
    Nov 2018
    N.E. Ohio
    I agree with old timer as I have a heated jacket liner and heated gloves. cueman
