Page 1 of 3 123 LastLast
Results 1 to 25 of 60
    Active Member ricford's Avatar
    Jun 2015
    Calhoun, La
    Default Magnetic mirrors
    Does anyone know just how many of us bought those fantastic magnetic mirrors. The initial flurry kinda outstripped those available but I expect now it's better. Still would like to know how many. I really enjoy taking mine off just to show off.
    Active Member FlyBoy2121's Avatar
    Aug 2018
    Canada
    I Ricford
    You should give more explanations ????
    I have never heard of this special mirror.
    FlyBoy2121
    Quote Originally Posted by ricford View Post
    2014 RT ltd , original original Cognac
    Active Member MeudtPG's Avatar
    Aug 2018
    Monroe, WI
    Just ordered a set from Lamonster. It appears that many folks are not using any mirror safety catch teather should something happen. Any good reasons for not using them? Are they that sure the magnets will hold it?
    "BLUE STAR – She shines so brightly"
    2018 SPYDER RT LTD SE6 BLUE/CHROME
    2018 RTL , Large Brake Pedal (cut 1/3 off). Oxford Blue/Chrome
    Nov 2012
    North Las Vegas, NV
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Durham,Maine
    I took a wire tie and ran it threw the wire connector so if it should flip off, the wire would be the safety wire. Seemed to be a good idea to me Good luck, and go get some Magic Mirrors you will not be sorry!
    2012 RTL , Pearl
    Quote Originally Posted by MeudtPG View Post
    I designed a simple easy to use sheet metal tab that prevents the mirror from coming loose or if it did, a 300lb. test line that prevents the mirror from falling more than 3 inches...………. " Utah Pete " has some pics that He might send you …… Happy New Year …. Mike
    Mar 2015
    forrest above Reno, Nv
    Magic mirrors are GREAT. If you don't have a set and do your own work on your ----- ya need this mod. Tether of some kind is a must ( IMHO ). How many of "us" have them? Contact the OEM.
    Lew L
    Happy New year to you all
    2014 RTS , Circuit Yellow
    Aug 2018
    Canada
    I Spyderman
    Ok new, These are magnetic fasteners for the mirror, very good gajet
    FlyBoy2121
    Quote Originally Posted by Lew L View Post
    Lew L
    Lew, imho you need the magnets MORE if you don't work on your Spyder - WHY … because dealer Tech's are more likely to Damage the OEM system or not properly attaching the mirrors, which then allows them to FALL off..... BRP doesn't make any system for preventing the mirror from hitting the pavement. A friend of mine bought a New RT, and both mirrors were Not properly attached...… Mike
    Aug 2018
    Monroe, WI
    Lew L
    Anybody want to submit pictures of what they are using for teathers? Thanks.
    Pictures tell a hundred words.
    RT-S PE#0060 Gordy's Avatar
    neepawa manitoba ca
    i dont use tethers ,have about 5000 miles on mine and on some extremely ruff roads dont move at all
    Sep 2014
    USA
    Fishing line works well.
    .... The 300lb test line I'm using is " fishing " line ….. the kind they use to go after Great Whites ……….. Mike
    Active Member Chasinsparks's Avatar
    Jul 2016
    Woodbine, Maryland
    I used the ones by Tricled. I would say they hold the mirrors far better than the OEM clips and less frustrating to get on and off.
    To be continued....
    Quote Originally Posted by Gordy View Post
    As stated above I use tethers …. they cost me a little time and about .10 to make ….. I don't think my mirrors can or will come off, and I only use Two magnets ….. But Paying approx. $250.00+/- ( for a new mirror assembly ) if one does come Off, well this is not a good option...……… Mike
    Very Active Member GOZFST's Avatar
    Oct 2014
    SD &AZ
    Mine came with tethers, best add on I've installed. Used to be the worst part of maintenance.
    Bob S
    Sep 2014
    USA
    The Magic Mirrors saved me a lot of aggravation. Was buying more mirror clips all the time and bending them to make the mirror hold on to the Spyder. Not anymore. One good tap and the mirror is off and goes back on just as fast.
    But still use the tethers that came with mine at the time. They dont come with them anymore from what I hear.
    Sep 2016
    Yukon, OK
    BEST added addon that I have! I will never again ride my Spyder without them on the mirrors. When I trade my 2016 in for a new model, the magic mirrors will be the first addon I get.
    2016 RTL , Orbital Blue
    Nov 2018
    San Diego
    It sounds like I better get a set too.
    2012 RT , Pure Magnesium Metalic
    Feb 2018
    Queensland Australia
    Absolutely up there with the best accessory [ maybe no.1 ] you can fit to a RT.
    INDIANA, USA
    Default Magic Mirrors
    A Big plus x 10 for magic mirrors.
    ENJOY YOUR LIFE WITH A SPYDER
    Faribault, MN
    As many have said, Absolutely one of the best accessory's you can add to a RT. I do most of my work on mine, and when I do take it in for dealer servicing, I demonstrate then to the tech and have a little tag that says magnetic mirror mounts that I slip in between the top magnets so it hangs back into the cockpit area.
    And to those concerned about tethers, After mounting the magnetic mounts (the 6 pack so all points mounted magnetically) while on a strange road very late on a rainy night in NE Georgia I drove my '13 RT over a railroad track crossing that had a maybe one foot ramp up on the approach, but a good two foot drop on the far side, I was airborne. When I landed both my un-tethered mirrors popped off. But they stayed connected to the electrical connectors that power the turn signals and just hung there while I came to a stop. Snapped them back on and continued the ride. No Damage, no problem.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Aug 2018
    Monroe, WI
    Wow! Did you have small wire ties between the electrical connectors for tethers?
    Very Active Member eddieshep999's Avatar
    Oct 2010
    Broadstone,Poole, Dorset, UK
    Eddie Sheppard
    Poole Dorset UK
    Get a Spyder - See the World
    Dec 2015
    Oakley Utah
    A lot, but not enough.
    2014 RTL Platinum
