Results 1 to 19 of 19
    Jul 2015
    Colorado
    Default Does the new Ryker have Cruise control? Or will I need to add?
    Does the new Ryker have cruise control, or will a person have to add it like I had to add cruise control on our '15 F3?
    2015 F3 , OEM None Black
    Aug 2015
    Crosby,Texas
    NO cruise control
    I'm guessing that it has something to do with the CVT transmission...
    Sep 2016
    Chillicothe, Oh.
    Possibly, but I think it is more about $$$$.
    2015 RT , Black
    Very Active Member Tslepebull's Avatar
    Dec 2018
    East Texas
    I wonder if any of the ThrottleMeister models would work?
    2019 Ryler Rally , Shock Yellow
    Active Member Michaelscs's Avatar
    Sep 2015
    Cold Spring, MN
    I agree it's probably about $$$$. The CVT shouldn't matter. The speed sensor would probably be located on the driveshaft or wheel and the throttle & CVT would just work to maintain the set speed.
    2020 RT Limited , Petrol Blue
    Very Active Member oldgoat's Avatar
    DDO, Montreal Island
    My Corolla has a CVT and cruise control
    2008 GS SM5, Full Moon Silver
    2007 Piaggio MP3 - 250cc
    Don't know for sure if the Ryker has the ability to add a cruise like the Spyders did.
    Since the Ryker was created from the ground up, with the thoughts of cost cutting (which they did well), I am guessing it will not be cheap or easy to outfit a Ryker as such.
    Dec 2013
    Even if there is no facility for an electronic Cruise Control on the Rykers, with the twist & go throttle & the CVT, you'd think they'd be ideal for one of the friction style 'poor man's cruise/throttle lock' devices.... something like the 'Vista Motorcycle cruise control throttle lock' that goes for less than $40 on eBay. They come in a variety of sizes to fit most common bar & throttle grip dia combinations, take all of 10 mins to fit, and are easily flicked on or off with your thumb. Back in the days before EFI & electronic throttles, they were pretty much all that was available, and they worked well - still should! And they should be ideal for holding a steady throttle setting on a CVT equipped machine!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Bossier LoUiSiAna
    Ryker not for LONG rydes so kept to minimal
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Aug 2007
    Greeneville, TN
    You can put an aftermarket cruise control on the Ryker. I've done this for several motorcycles and my 2008 GS Spyder. It's a bit of work but they sure are nice to have. The newer electric models are better than the old vacuum versions. Especially on a motorcycle which makes very little vacuum compared to most cars.
    The biggest issue is making it waterproof.
    Sep 2021
    Pennsylvania
    My wife has a 15 F3 and wants to add cruise control, can you tell me about yours?
    Aug 2019
    Stoughton, WI
    (4) year old thread. Do a new search for cruise control on Spyder F3.
    2022 RT Sea To Sky
    May 2016
    Noblesville, Indiana
    I just upgraded from a 2019 to 2022 rally. On my old bike, I had an atlas throttle lock that worked really quite well. The new rally has electronic cruise control as standard equipment. It’s really interesting that I primarily still use my throttle lock rather than the cruise control. I use the throttle lock because it’s very convenient and fast to engage and disengage with only my thumb on the throttle hand. The cruise control takes more time as you turn on the cruise control and then wait to the proper speed and then push the button again and hold it for a second or two to engage the cruise control. So, I only use the standard equipment cruise control on long distances/interstate driving and I rely upon my atlas throttle lock for all other cruise control type needs.
    RykerUSA
    2022 Ryker Rally
    Oct 2021
    Ontario
    The 2022 Rally and Sport models come with cruise control.
    I believe that BRP also lists one you can install yourself.
    Oct 2021
    Ontario
    The BRP part no. for a Ryker cruise control is sku219401135.
    Active Member DickB's Avatar
    Jun 2021
    FL
    Quote Originally Posted by Raven View Post
    That's just for the button. I believe you also have to get the ECU reflashed to add the needed software. A member of the Facebook group Ryker Mods did, at an additional cost of $200.
    Jun 2021
    FL
    Quote Originally Posted by RykerUSA View Post
    The ergonomics of the factory Ryker cruise is not great.
    I added a Rostra cruise control to my 2019 and used these buttons. They are easier to reach than factory and react instantly, just like your car.
    Oct 2021
    Ontario
    Quote Originally Posted by DickB View Post
    The Can-Am site lists it as a cruise control and easy to install.
    Check it out, might not be perfect, but you never know.
    Talk to a Can-am dealer, he should be able to tell you if a reflash is needed.
