Results 1 to 9 of 9
    Oct 2015
    Default transmission oil filter
    I have a 2014 RTL with the 1330, how often do i have to change the transmission oil fliter
    Mar 2013
    BRP recommend change is every 28,000 miles. I do it at the next oil change that is the closest mileage to the 28,000 since the last time - even if it is over.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Quote Originally Posted by PW2013STL View Post
    Correct...
    Sep 2014
    USA
    add very easy to replace when the time comes. Ron has the filters when you need one.
    Northern Kalifornia
    That one little cap screw on the lower left is a tight fit. Use a 1/4" torx that fits the head of the screw (they're all the same) and a 1/4" open/box end wrench and it comes out 1/2 turn at a time.
    Page 122 of your operator's guide.
    Houston
    None of the fasteners on the Spyder are 1/4" They are all metric and Torx
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Mar 2013
    I believe 2dogs was referring to the drive size. I know that up to T30 my Torx bits are 1/4" drive. The wrench should be metric size.
    There are a few places where space is tight that I've found the tool that works best is like a T30 torx with 1/4" hex shaft. Put the torx into the screw head and turn it with a 1/4" open end or gear wrench.
