Results 1 to 23 of 23
    Mar 2013
    Clarksville TN
    Default Rear tire (automotive) pressure?
    I just installed a Kumho Ecsta on my wife’s F3. I did a lot of searching on this forum regarding suggested tire pressure. I found a variety of different numbers in parts of misc threads and thought we could use this single thread to consolidate many suggestions in one place. This will make things simpler for those doing a search in the future. So, what psi have you found suits you with your car tire on your F3?
    2015 F3 (wife's)
    2014 Indian Vintage
    2019 AMG C43 cabrio
    1966 LS1 Corvette restomod
    1956 Corvette survivor (wife's)
    1941 Chevy hotrod truck
    2023 Corvette Z06
    Dec 2012
    Murphy, NC
    I run 20 psi in my General Altimax rear tire. Smooth ride and even tire wear.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Based on watching SL for more than four years and now on my first auto tire, I would say that unless you find a poster who is exactly the same weight as your wife and who rides exactly like your wife and has a Kumho Ecsta, you or your wife are kind of on your own in determining the optimal tire pressure for her. Your biggest difference I think is the stiffer auto tire sidewalls. I'm still playing with rear tire pressure on my Altimax but began at 28 pounds and have been going down, am now at 26. The one thing I have not done yet is really push the Spyder in the NC mountain twisties, but I suspect if I was going on a ride to do so I'd probably drop to 24. No two Spyder riders ride exactly alike.
    Very Active Member AeroPilot's Avatar
    Nov 2012
    Pueblo Colorado
    Wifes 16 F3T has 24 psi cold on her General Altimax .. before that she had 26 psi on the Kumho. She has 40,000 miles currently and only weighs 110. Works for her. The fronts are usually 17 psi or so as it seems to steer and perform well there. Your choice...
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
    2015 RT , OEM Black Gloss
    Tire pressure in an Auto tire …………. because Auto tires are almost THREE times as strong as the OEM Kenda, it doesn't need more than ( approx.. ) 18 PSI to work at it's optimum performance...… Think about this - a tire that can support 1300 to 1400 lbs. is not going to be ( realistically ) affected by a load change of even 150 lbs. ………. If you are concerned about a weight change - how many of you increase your CAR or Truck air pressure when you fully add passengers for a trip ???? … I think maybe 10% will do this …….. I ride aggressively in the Twisties and keep my ( rear ) AUTO tire @17 psi. I'm very happy with the way My RT responds...……… good luck ...Happy New Year …. Mike
    May 2016
    Tombstone Az
    The problem with arguing tire pressure is the gauges used. When my tire is 20psi using my gauge it might be 18 or 22 using your gauge. Using a calibrated gauge helps but there are lots of people using gauges that are no where close to correct. I run my altimax at 18 to 20 using a gauge certified +/- 2%. And, just because a gauge is digital does not mean it is more accurate than an analog one.
    Dec 2016
    Somewhere USA
    Since you put an untested unrated tire on your Spyder you need to do tests yourself.
    1. Load your bike as if you are going to ride it.
    2. overinflate your tire and slowly release air until all the tread makes contact. (note the pressure)(you need to eyeball it with your head on the ground)
    3. you need to do breaking tests and adjust accordingly.
    Many moons ago I added a 4" lift to my Ford Bronco and added monster unrated tires to it.
    Since there were no citations, tire ratings and internet at that time this was the method used and it works.
    Quote Originally Posted by petegtsv10 View Post
    Active Member wingit3611's Avatar
    Dec 2016
    Louisville, KY 40214
    2016 RTL SE5 Kumho Ecsta 225/50-R15 91H @ 25lbs. Still need to go down. Mite just jump down to 20. Vee rubber on front @ 19lbs.
    Can Am 2013 RTL SE5
    Dec 2015
    Oakley Utah
    Quote Originally Posted by JKMSPYDER View Post
    2014 RTL Platinum
    Mar 2013
    Clarksville TN
    Quote Originally Posted by Beaudog View Post
    My gauge is calibrated about once a year. So is my torque wrench.
    2015 F3 (wife's)
    2014 Indian Vintage
    2019 AMG C43 cabrio
    2023 Corvette Z06
    Mar 2011
    oregon
    The way the racers do it is chalk the tire then with the load that will be used roll the bike or car across smooth flat concrete with dark paper and look for even caulking marks to much there will be more in middle to little more on edges and cupping in middle
    2 happy happy spyders
    Mar 2013
    Clarksville TN
    Thanks for the input. I now plan to start at 20 psi and adjust up and/or down from there. I'll base my final decision on handling characteristics, comfort and application of the 4 psi concept. At least now I have a good initial psi.
    2015 F3 (wife's)
    2014 Indian Vintage
    2019 AMG C43 cabrio
    2023 Corvette Z06
    Aug 2012
    Central Coast, CA
    Also go for a ride and get the tire fully warmed up and then measure the air pressure using the same gauge. Then compare that figure to the figure you already have from the cold inflation and check for variations between warm and cold numbers, that's a good indication of heat build up.
    The air inside of the tire is also used to cool the rubber, so if it's too low heat will build up and cause premature wear. This is an often overlooked concept when discussing tires and air pressures.
    2020 RTL SE6
    May 2009
    Connecticut
    I'm at 21-22 on the New Kumho on F3 200 Pounds- At 24 in the summer it would spin much more than the stock so I lowered it to 21 and in the cool weather 38-50 degrees it seems much better. I'm more careful in cold weather because it doesn't heat up the rubber like summer!
    Sea Doo GTI-SE 90 Jet Ski!!
    Active Member always young's Avatar
    Oct 2015
    Melbourne, Fl
    Reference wingit3611, he mentioned that he is running a Kumho 225/50R15 on his RTL. I'm pretty sure the 2016 F3 has the same swing arm as the RT. The numbers on the Kumho width for the 225/50 seems to be wider then the OEM tire. My question, for you, do you have sufficient clearance to the belt with this size and not have any belt rubbing on the tire? I'm looking to replace my stock tire soon and was looking at the 215/55R15 and I was wondering which size would be a better choice. Thanks, and have a happy New Year everyone!
    Life is attitude, be positive!
    Mar 2013
    Clarksville TN
    No clearance issues on our F3 with the Kumho.
    2015 F3 (wife's)
    2014 Indian Vintage
    2019 AMG C43 cabrio
    2023 Corvette Z06
    Nov 2013
    Oro Valley Arizona
    You recalibrate your tire gauge once a year? How in the world do you do that?
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Nov 2013
    Oro Valley Arizona
    Nothing more exciting than to read about everyones opinion on tire PSI!
    Jack
    2015 BMW R1200R LC
    Mar 2013
    Clarksville TN
    [that improves life’s QUOTE=jaherbst;1411986]You recalibrate your tire gauge once a year? How in the world do you do that?
    Jack
    [/QUOTE]
    I send it to Accugauge and they calibrate it. Probably not quite as often as once a year, but it’s been done several times. Many cars I’ve owned use ultra expensive tires ( like 355x20 Michelin Pilot SuperSports) and I want to monitor their psi closely. That improves lifespan and optimum handling characteristics.
    2015 F3 (wife's)
    2014 Indian Vintage
    2019 AMG C43 cabrio
    2023 Corvette Z06
    Dec 2016
    Somewhere USA
    Even more exciting is people who think PSI and traction are the same thing.
    Quote Originally Posted by jaherbst View Post
    Jack
    Mar 2015
    forrest above Reno, Nv
    And here we go again.
    2014 RTS , Circuit Yellow
    Quote Originally Posted by Road-Kill View Post
    …...they aren't , however they are closely re-lated ……. Mike
    Dec 2016
    Somewhere USA
    They are but not by much otherwise tire manufacturers would just have everyone adjust pressure accordingly.
    Tread density is what saves the day.
