Time delay prior to covering Syder
I have just purchased a full cover for my bike. Question: Do you wait for the bike to cool prior to covering? If so, for about how long? Problems??
Thanks!!
2016 F3T Limited
F4 Windshield, LaMonster backrest, headlights, foglights with rings, Long Horn mirror lights, saddle bag and fender lights, swaybar, cat bypass, Centrtonics balancers, Fobo, Baker hand and lower wings, laser alignment, Dual power plate,Givi E47 center bag, Sensa 20s, Pitbull highway riding pegs, Tricled highway lights, empty bank account
As long as you can hold your hand on the end of the muffler:
Thanks!!
Since my Spyder generally lives in the garage I don't use my cover. I do put a small old sheet over it to keep dust off it. The sheet doesn't touch the muffler. Until the muffler cools a bit it could possibly burn a cover. So do what Bob posted …… Mike
Thanks!!
I think all you have to be concerned about is the hot exhaust pipe(s). I'd be more concerned about putting it under full cover if it is still wet, and then only if it's going to be an extended period.
2014 RTL Platinum
Agree...
couple of things... depends on the cover as some are plastic or have plastic lining so that would be the points that can melt on a hot muffler. Others have a protective barrier around the exhaust area so you could do that one right away. Some of the plastic ones can have condensation if hot and the temp is cold...
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
I have the Ultraguard cover for my Spyders and I put the cover on as soon as I am done riding - F3 and RT.
Love my Spyders
2016 F3L Steel Black purchased 7/16/2016 Sold 3/11/2023 (22,500 mi)
2014 RTS Circuit Yellow purchased 3/2/2018
2020 RTL Petrol Blue purchased 1/27/2023
Girls on Spyders #3195
No more 2 wheels
2020 RTL , Lamonster floor board riser Petrol Blue
+1 on the Ultraguard cover. It has a panel on the inside that is a heat shield for the exhaust. It gets put on a few minutes after shutting down and mine shows no signs of heat damage. Also very water resistant if that is a consideration.
