Results 1 to 25 of 35
    Dec 2018
    KS
    Default Handlebar rotation
    The handlebar has a bit of a u-shaped profile that is biased away from the driver (i.e. the centerline of the bar where it passes through the cam clamp is closer to the driver verses the centerline of the grips. Anyone have experience loosing all the attached items and rotating the handle so it moves the grip centerline closer to the driver?
    2019 Rally , Black on black
    Default So I see....
    you have a Ryker Ralley, I don't know but have you checked the owners manual .. ?? We all know the bars slide for and aft but not much on the pivoting....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Dec 2018
    KS
    Maybe I missed it, but didn't see anything about the option of rotating the handlebars. Seems like it might be doable???
    Bossier LoUiSiAna
    If its not in your manual then best ask your dealer. These are new machines all around & we still learning, please share when you do find the way.
    SoFlo
    Quote Originally Posted by CTAC View Post
    A photo would have helped, but it sounds as if the handlebars were installed incorrectly if that is possible.
    Nov 2018
    N.E. Ohio
    At the show I went to dealer said you can rotate them a small amount. It seems that the switches are mounted in a pinned position so if you rotate, switches will also rotate as well. cueman
    Dec 2018
    KS
    Thanks cueman. Was hoping they were just clamped on. Appreciate the information!
    Aug 2015
    Crosby,Texas
    Yes you can rotate the bars, BUT you would have to re drill the hole to match the wiring and controls. Anything is do able if you are capable.
    Jul 2010
    Las Vegas, NV
    If I had one, I would flip the bars over. I’ll bet it just takes a drill to locate the positioning pins.
    Joe Meyer
    Sep 2016
    Chillicothe, Oh.
    I didn't drill the bars on my Triumph when I wanted to rotate the switch housings. I just used my Dremel tool and took off the positioning pins. The housings still tightened enough to keep them from rotating on the bars. Put three years and 70,000 miles on the bike with no issues.
    2015 RT , Black
    Dec 2018
    KS
    Good to know!
    Dec 2018
    KS
    Got them flipped/rotated. If anyone else wants to get the stock bars higher and a bit closer to you, let me know and I can tell you what I encountered in the process.
    Love the new position!!!! Worth the effort for my riding style!
    SoFlo
    Are you saying the end of the handlebars was forward vs what you show in the photo? If so, it seems the bike was assembled incorrectly.
    Sep 2018
    Texas
    They look much better. What all was involved in the flip??
    Bossier LoUiSiAna
    Glad your happy with results, without too much detail, was it a DIY or dealer involved task?, & guess on time to complete please.
    Dec 2018
    KS
    It was a DIY project. And responding to an earlier post, they were not originally installed incorrectly... Just not to my liking. By rotating them approximately 180 degrees after flipping them, they sit taller and a bit closer to me. It took me a couple hours but others might be able to do it faster. I was being very careful.
    The details of what I did:
    - Removed the mirrors (one Torx screw per side)
    - Removed the hand guards (four socket head cap screws per side)
    - Loosened and seperated the throttle casing halves and the throttle grip itself (three Torx screws)
    - Loosened and seperated the turn signal/horn/lights casing halves (two Torx screws)
    - Removed cables from cable holders (carefully)
    - Removed bar clamps and screws (four socket head cap screws)
    - Flipped handlebar end-for-end and ensured I slid the throttle housing over handlebar end before placing into the adjustment cradle.
    - Replaced the bar clamps and screws. Test fit preferred angle then fully tighten the four socket head screws.
    - Inserted a thin screwdriver between grip and handlebar; prying outward to form a gap... then sprayed isopropyl alcohol in the void.
    - Twisted and remove grip
    - Sprayed isopropyl alcohol inside of grip and slide it on the other end of the bar to the same distance as before
    - Marked, center punched, and drilled holes for the pins for both end casings.
    - Reassembled the handguards . Note: Since my preferred riding position was about a hundred 180 degrees from where it was, I could utilize the same pin holes for the hand guards after it was flipped end-for-end.
    - Reassembled the throttle casing, ensuring the throttle grip was properly seated in the casing halves.
    - Reassembled the turn signal/horn/lights casing halves
    - Placed the cables inside the cable holders
    - Installed the mirrors
    Jul 2015
    Saint Michael, MN
    Handlebars might be a great aftermarket possibility for the Ryker!
    Active Member Michaelscs's Avatar
    Sep 2015
    Cold Spring, MN
    Quote Originally Posted by Gunner3773 View Post
    Can-am has 2 addition handlebar options for the Ryker. The Cross-Style & Sport. https://can-am.brp.com/on-road/shop/...andlebars.html Both are priced at $100.
    CTAC thanks for your detailed description of your DIY handlebar project. Probably a great way to save a 100 bucks with just a little extra labor.
    2020 RT Limited , Petrol Blue
    Dec 2018
    KS
    At least we know know it can be done on the cheap. Next project is the under body light kit.
    Dec 2018
    KS
    Cup holder installed. Gotta have one of those!
    Very Active Member Tslepebull's Avatar
    Dec 2018
    East Texas
    How about a photograph of you (or a proxy) sitting on the bike with your hands on the grips? It would give us a reference.
    2019 Ryler Rally , Shock Yellow
    Dec 2018
    KS
    Not sure if this picture will show exactly what you would like to see.
    Next project is add a lumbar support! I am gonna do my best to make this a pseudo touring machine.
    Dec 2018
    East Texas
    I am thinking something similar. The tail trunk will be my back rest. I think I am going to hold off on the SHAD side bag and see if the aftermarket offers two bags. Even if they are different sizes. A lot will depend on range to fill up.
    Active Member NM Wrench's Avatar
    Apr 2014
    Albuquerque, New Mexico
    I did the Handlebar rotation yesterday and am a little disappointed. It went well but after inverting and rotating 180 degrees the wire hold down and drainage holes have ended up on the top of the bars. I am now looking for some small rubber plugs to fil the holes before spending a hundred bucks for new bars from BRP. Can anyone help me figure out what I might have done wrong? My wife needs the bars at this position so she can ride upright and not leaned over for comfort.
    14 RT-S , Stock Large brake pedal White Pearl
    Dec 2018
    East Texas
    Quote Originally Posted by NM Wrench View Post
    How about a little bit of colored silicone sealer in the holes?
