Front brake rotors
Can anyone tell me if front brake rotors off a 2012 RT . will fit on a 2014 RT . ? thanks.......
If you go on cheapcycle parts web site there not the same part number. I don't recall when they went to the Brembo brake system, that may be the difference! Good luck
If anyone has accurate info on this it would be …..BAJA Ron …………….Merry Christmas ….. Mike
I believe the wheels on a 2012 are 14” and on the 13’s” and newer they are 15”. Also, 2013 was the first year of the Brembo brakes. I don’t think those rotors will work.
2020 F3 Ltd
Spyderpops Bumpskid
Spyderpops Brake/Run/Turn Signal LED's
Lamonster Garage LED Fog Lights and Headlights
2013 ST-S retired 1/9/16 at 25,061 miles
2015 F3S sold at 77,565 miles.
SpyderLovers Sponsor
Joe Meyer
Little checking.....
suprisingly cheapcycleparts.com has both models with the same part number. This would indicate they are interchangeable part numbers are the same up to 2017 the 2018 has a new part number...
2012 RS sm5
Didn't look at the CheepCycleParts web page. But I can tell you for sure that they are NOT interchangeable.
2008-2012 used the BRP engineered, Chinese made brake components. All of these years and models have interchangeable brake parts
2013-Current - This is when BRP made the chassis change and went to the much better Brembo braking system. All brake components in these years and models are interchangeable.
Nothing (brake wise) is interchangeable between these 2 production types.
I don't know about the Ryker yet. But I will.
I can say that EBC rotors are the way to go. I've never had a customer with an EBC rotor have it fail. And some after going through 2 or even 3 sets of BRP rotors. Highly recommended. They will stop better as well.
The EBC rotors are so much better especially when combined with the EBC you wont believe the difference. Love my EBCs.
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
