Results 1 to 19 of 19
    Active Member mully's Avatar
    Jul 2018
    Harrison, wisconsin
    Default home made trailer hitch
    Welded a home made trailer hitch on my F3s out of 1/4" steel and added a LED tail light. Won't be able to try it until next spring. What do you think?
    2018 F3s, 2016 versys 650LT, 2001 concours 1000
    Quote Originally Posted by mully View Post
    …….. I applaud your workmanship, I've made a few myself, but they wouldn't compete with your workmanship … You state " 1/4 inch ", I don't understand how you came up with that thickness as being necessary ….. The MAX you are told by BRP is a load of 400lbs.....it would be one thing if your trailer didn't have wheels and you were dragging it with the frame on the ground...… but with it rolling on wheels, it doesn't take much force to move a 400lb. load...… as an example :When I was 67 I was able to move my snow-mobile trailer with two machines on it. Total weight of that was 1600 to 1700 lbs.... I'm no Charles Atlas, kinda ordinary strength - wise, but I could maneuver it without much difficulty...….. Yours is beautiful tho ……. Mike
    May 2012
    Panama City, FL
    and on your hitch. Dale
    Active Member tibadoe's Avatar
    May 2013
    Gladys, VA
    Nice job on the hitch.
    Joe
    2023 F3
    Default Excellent
    Nicely done will wait with you to see the test results... I'm sure they will be great...
    ​2012 RS sm5
    May 2017
    Mesa, Arid-Zone-A
    Very nicely built. Looks like you could pull stumps with it
    Semper Fi
    Nov 2016
    Upstate NY
    Interesting, but where will you put your license plate now?
    2021 Sea to Sky RT , Highland green
    Jul 2018
    Harrison, wisconsin
    Relocated under tail light, I'll try and get a picture when installed.
    May 2012
    North Las Vegas
    Very Nice workmanship!
    USAF MSgt, Retired
    2018 F3 Intense Red
    Squared Away Lasar alignment, TricLED Headlights, Foglights,Safety Bundle with Turn Module, BajaRon Sway Bar,Squared Away Mirror Wedges, Stebel Air Horn, Dash Turn Indicators, TricLED USA Flag
    2018 F3L , Intense Red
    Oct 2014
    Idaho
    That is the best looking trailer hitch I've see for the F3. You did a great job on it. Have you come up with a wiring harness yet that will not mess with the F3 electronics?
    Member 311tomcat's Avatar
    Feb 2017
    Poinciana, FL
    You've done a good job on that hitch. Been so long since I've welded, that I probably couldn't lay a decent bead!!
    Nov 2018
    San Diego
    Mmm, it’s pretty.
    2012 RT , Pure Magnesium Metalic
    Jul 2018
    Harrison, wisconsin
    Quote Originally Posted by Grandpaspeed View Post
    Thanks, I ordered this https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 hoping to make up my own harness.
    Oct 2014
    Idaho
    Thanks for your reply and look forward to how it works out.
    Jul 2018
    Harrison, wisconsin
    Here a picture with hitch installed with license plate relocated. 20190112_161414 (2).jpg
    Mar 2013
    Looks good, but where do you attach the safety chains too?
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Jul 2018
    Harrison, wisconsin
    Quote Originally Posted by PW2013STL View Post
    Thanks, here a different angle that shows the tabs welded underneath. 20190113_124309.jpg
    Jul 2018
    Harrison, wisconsin
    20200721_114109 (2).jpg Update on my homemade trailer hitch, just got back from deadwood three wheeler rally (1900 mile round trip) and it's holding up good. Estimate about 5000 miles total pulling trailer that my wife likes to load up real good. Have since relocated the license plate to rear fender because the tire keep hitting it when I had it mounted directly under the tail light.
    Mar 2017
    Well done!
