Results 1 to 11 of 11
    Nov 2018
    Claremore, Ok.
    Default Handbar movement?
    Handlebar moves about 1/2" at the ends without moving the tie rods. I that normal?
    Mar 2013
    With it running, or off?
    What model?
    What year?
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Dec 2013
    Quote Originally Posted by Revalden View Post
    Short answer is 'YES', with some proviso's; but what PW2013STL asked above is fairly important to really make any further discussion meaningful.... I'm guessing an early RT with the 1330 motor??
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Very Active Member 4 MARIE's Avatar
    Apr 2014
    Beloit Kansas
    yes...normal, or maybe a little less than normal even
    Flatlander, Navy Veteran, Widower
    Loved my 2014 RTS SE6 Pearl white
    but have a new love now,
    my 2017 RTS SE6 Champagne metallic (Champ)
    Quote Originally Posted by 4 MARIE View Post
    …… just think, if there wasn't some free play, I think the Spyders would be almost un-controllable …………….jmho …… Mike
    Very Active Member KX5062's Avatar
    Aug 2012
    Central Coast, CA
    However, there is a known issue with the steering knuckle bolt coming loose over time. Most dealers know about it and it can be fixed by tightening the bolt without any drama.
    2020 RTL SE6
    Default Curious...🤔
    are we talking full free play or spongyness. I find when running lower tire air pressure (especially on Kendas) the steering feels like it has play went moving about engine off...
    ​2012 RS sm5
    Very Active Member jtoro1's Avatar
    Feb 2013
    port st lucie fl
    No it is not normal I will be going to a dealer to get mine fixed I road a friends bike and it has no play , I was told it's the center steering rod I had a friend that got it fixed
    Aug 2012
    South Carolina
    mine was like that and had to have the steering columns replaced due to broken spline teeth.
    Nov 2018
    Claremore, Ok.
    Quote Originally Posted by PW2013STL View Post
    What model?
    What year?
    It's a 2015 RTS SE6 Special Series. Noticed it in garage. When the weather warms up I'll get it up on jack stands and check for loose bolts or nuts.
    Nov 2013
    Oro Valley Arizona
    All the experts tell me it is quite normal. I have the same and stopped worrying about it. If you check 10 RT's you will find 8 of them have about 1/2 " play with engine off. I do not notice it with engine running.
    If it where completely tight, at our age and shaky hands we would be all over the road, Right!
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
