Results 1 to 5 of 5
    Apr 2012
    Arizona
    Default Jacking up the F3 S
    Need help finding the pictures of jack placement. Can't remember where they are. Know Lamonster posted some but all gone from memory
    . At 85 guess thats to be expected. Want to remove front tires to have cars put on. Thanks for any help.
    Mar 2013
    Using my Sears atv/motorcycle lift I slide the two jack arms under the Spyder so that the rearward arm is just covering the rear of the main frame that runs down the center of the Spyder. I then jack it up and place car stands under each lower A arm. I than lower the Sears lift so that the Spyder rests on the jack stands.
    Remember to loosen the lug nuts before raising the Spyder.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Apr 2012
    Arizona
    Thanks PW sounds like its the same as my RSS.
    Active Member OK-DZ9R's Avatar
    Apr 2017
    Oklahoma
    The extra piece on the lift was to get enough height to install the sway bar.
    2015 F3 S , Can Am Red
    Apr 2012
    Arizona
    Thanks OK good picture.
