Results 1 to 16 of 16
Thread: CB types etc
    Dec 2018
    KS
    Default CB types etc
    I have no doubt there are a few threads on here about CB's but I cant find them. Am considering adding one to my 14 Rt-se6 , any good recommendations, pointers on helmets etc for this?
    Active Member thereverend's Avatar
    West Monroe, LA
    check on Midland handhelds, there are some youtube videos of installs on Spyders. I installed a midland on my spyder and my wife's using a non groundplane antenna from Sierra electronics. You can use a Sena SR10 bluetooth to listen to thru helmet with a Sena headset. Visit one of the vendors, "motorcycle Dave", he has the answers.
    May 2017
    Mesa, Arid-Zone-A
    I have an uninstalled CB for the Spyder RT. Let me know if you decide to go that way. It is listed on this forum in the For Sale category.
    Semper Fi
    Nov 2016
    Upstate NY
    how is the range on your midland handheld? I have a midland handheld and it wont reach even a quarter mile. And, how the heck are you listening to your CB through your SENA? The midland handheld does not have bluetooth.
    Aug 2013
    SF Bay Area
    Quote Originally Posted by Joel The Biker View Post
    You need the Sena SR10 BT adapter and cable specific to the Midland CB. I use a Transit Escape bicycle bag modified to fit on the glove box with the Midland CB inside and a 90 degree Coax antenna adapter so the antenna sticks out through the top. TransIt https://www.performancebike.com/shop...be-bag-40-5196
    I have the Sena SR10 velcroed to the handlebar as it's waterproof and has the PTT button but you can get a small PTT button that can be attached closer to the left hand. If you want.
    The range is not far as it uses AA batteries. I'm working on trying to use one of those battery jumper units that can also charge devices and a USB/cig power adapter to power the CB and maybe it will put out better. The few times I've use the CB with AA batteries I can hear fine but some riders at the lead and tail end don't hear me. If I were riding all day with them, I'd get a shielded power cig power outlet to power the CB. It has to be shielded otherwise there will be engine static interference.
    2021 F3 Ltd , Magna Red
    Apr 2017
    North Central Florida
    J&M makes a good handlebar mount motorcycle CB but it is about as expensive as the "stock" one from BRP........and integrating it into the rest of the audio system might be tricky.
    I added a stock CB to my '17 RT (actually the dealer did it) and they had to get two additional different harnesses to make everything work.
    The range of any unit in my riding group is only about a mile.....Honda's, Harley's and Spyders.
    Mar 2016
    Palm Harbor, FL
    Ah, but the factory unit integrates so well with the rest of the Spyder audio system. With the cable to helmet unit I have AM/FM and XM radio alone with the CB and Navigation audio for however long I ride the Spyder RTL. Love it, although I do wish it had been cheaper. You can’t get this integration with a handle bar mounted CB.
    Apr 2017
    Quote Originally Posted by Dc8cappie View Post
    Not with a "hand held" either.
    One of the J&M models has Bluetooth for helmet connection but I still don't think the "integration" would be nearly as good.
    I have found that the audio from an actual phone call will come through the factory system too, if I pair my phone with the GPS.
    I haven't seriously tried to see if I can talk back with that arrangement yet.
    Quote Originally Posted by piperpilot75 View Post
    Do a Google search with the following in the search box: "CB radio site:spyderlovers.com". (Don't use the quote marks.) The forum search won't search for any word less than 4 characters.
    With the factory CB your headset choice is limited to wired, no BT. There is a BT option for the bike audio system but it uses the same connection as is used for the CB so you have your choice, BT for bike audio and use a handheld for CB, or BRP CB with wired headset only.
    Sena has what they call the Freewire to provide a BT connection to an OEM CB, but they don't have a cable for the RT. From looking at various wiring diagrams I think a Harley cable could be modified for the RT but I don't think anyone has done it. I've not caved into the BT helmet craze yet so haven't pursued that option.
    Mar 2016
    Palm Harbor, FL
    Called Sena about that. Their answer was it won’t work with the Spyder. I got the impression they are not interested in making one for the Spyder. I guess they don’t think there are enough people with this set up to make it worthwhile. I guess I should call again and see if they will tell me how to reword the Harley-Davidson one for the Spyder.
    Aug 2013
    SF Bay Area
    Interesting that the manufacturers control what we want rather than the customers. We all need to email or communicate to them what we want and not buy what they think we want.
    What I would suggest you do, which is what I would do if I wanted to BT connect to my CB, is this. Buy the HD version of the Freewire adapter. Then go to Edsets.com, or maybe even just do a Google search. Ed has pinout diagrams for his lower headset cords that plug into the bike. Using those for a guide make up a short cable with 7 pin DIN connectors, female and male. Solder wires to the pins on the female end, which the Harley cable will plug into, and then solder them to the appropriate pins on the male connector that plugs into the Spyder connector. HD and Spyder DIN use two pins for the microphone and three pins for the speakers. The specific pins are all that is different. The HD connector has a pin for a handheld mic and the Spyder one a pin for connecting to the shield. I would leave both of those unconnected. Each one also has an unconnected pin.
    Another option to use the HD cable is to buy another driver headset harness (or use the one you have), p/n 710003387 and rearrange the pins in the rectangular connector so that the pinout of the DIN connector is the same as a HD DIN connector.
    Nov 2018
    Claremore, Ok.
    If ya want it "to put out better" ya need to apply lotsa ALCOHOL. I crack myself up.
    Have you tried a shielded cable? I wonder if that would help, really. The reason I'm wondering is I think the engine static is carried throughout the entire wiring harness. Shielding would help keep external radiation out of the cable but noise that travels in the wire. When my nephew and I went to Homecoming last year he used a handheld and SR10 that I had. It worked pretty good, but the range is limited as you've said. We couldn't use a 12 volt power cable plugged into the trunk power port. The static was so severe communication was impossible. I don't know how much better the range would be with a 12 volt battery source but I'm thinking not much. We did find however, that the batteries lasted for about 2 days plus of all day riding so I wouldn't be concerned about battery life per se limiting your use of a handheld.
    Apr 2017
    You are exactly correct.
    Most of the problem noise is produced INSIDE the 12 V system and shielding would do nothing to it.
    My "factory" CB has fairly pronounced "engine noise" when first starting out while the battery is being recharged.
    After riding a few miles, sometimes maybe 15 or more, the static when receiving a weak signal almost disappears.
