Question about GPS Mount
Just bought a 2012 RT Limited. Took the old GPS off - it was mounted on the bottom two of the four bolts on the steering column just below the key. When I took off the mount, there is a hole there in the steering column where the wire used to come through. There is not cover for that hole.
Anyone know what that little part (to cover that hole) is called? Or where I can get it?
Thanx.
There is a picture of that widget on the Steering but it says not available; however, on the diagram for the 2013 RT bars, Item #280, Cap, Deep Black, PN709401292, $11.02 ($10.99 at Cheap Cycle Parts) may be the item you need. Sometimes when a part number is listed as not available, as on the 2012 steering parts diagram, it is because there has been a part number change and BRP does not go back and make changes on the public parts lists we have access to. Check with your dealer to verify.
