Results 1 to 9 of 9
Thread: Deleting Posts
    Nov 2012
    North Las Vegas, NV
    Default Deleting Posts
    Where has the delete function at the bottom of my post gone?
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Server Admin AnthonyG's Avatar
    Aug 2007
    mi
    2018 F3 , Red
    Mar 2015
    Brockport, NY
    No pun intended, but I believe the delete ability has been deleted for users of forum and is now system admin/ moderator function
    2014 RT-S Pearl White
    Dec 2015
    Oakley Utah
    It's been removed so the forum will rank better in Google search engines, as I understand it anyway.
    2014 RTL Platinum
    Default There you have it....
    you do have the option to close but not delete....
    ​2012 RS sm5
    All above are right on the money.
    Apr 2017
    North Central Florida
    AND you have the option to delete by editing and removing ALL of the text.
    RT-S PE#0412 TicketBait's Avatar
    Dec 2009
    Santa Monica, CA. USA
    Quote Originally Posted by Easy Rider View Post
    unless someone has quoted you
    Yup--on the quotes.
    Your personal delete will remove what you said from any post.
    If others have quoted you, that will remain unless that person deletes it.
    Bottom line--probably not good to say anything that you don't want to be shouted from the mountaintops, because sometimes it is.
