Results 1 to 9 of 9
Thread: Gas drip
    Nov 2017
    Florida
    Default Gas drip
    2016 rt-when bike sits over night and started in morning gas drips for a few seconds then stops for the rest of the day. Any thoughts on this
    Bossier LoUiSiAna
    FIND IT ! Naked spyder time & or dealer before end of year. Please
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Default Interesting....🤔
    But would need a bit more info to guestimate.... like where the drip shows up under the spyder..? may have to pull panels to see if it is coming from the tank/fuel pump... fuel filter, evap canister, fuel cap area or more forward around the throttle body intake area.
    ​2012 RS sm5
    Sep 2013
    Houston
    This needs to be found and corrected NOW. Not later. Very dangerous. Do not be the next Spyder-B-Que...
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Very Active Member KX5062's Avatar
    Aug 2012
    Central Coast, CA
    Absolutely. This is not normal and is potentially very serious and dangerous.
    2020 RTL SE6
    May 2018
    millsboro,delaware
    Start by taking the covers off around the motor and seat area.Look for stains around any hose or pipe that could indicate a leak.Sniff around to help find the area.Many fuel system seals are made of rubber O-rings or gaskets and when running under pressure they will expand enough to seal properly but after the pressure bleeds off then they may shrink and lose that perfect seal.
    : 2017 RTL ORBITAL BLUE
    Bossier LoUiSiAna
    Quote Originally Posted by jcastiglia View Post
    Any update??
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    SENA 20S EVO
    Dec 2013
    As others have asked, where exactly do you see these drips? Under the engine area? Out of the end of the exhaust? Under the fuel tank or mid/tail of the machine? Telling us the general area of this drip could make it a whole lot easier to help....
    It's not just dripping out of the exhaust is it? The little bit of dripping that most modern gas engines get from their exhaust when starting up after sitting overnight (especially on cold damp nights) might smell a bit like gas; but it's almost invariably just condensed water vapour that's a touch contaminated with improperly burnt gas & exhaust fumes & the drips usually go away once the engine reaches its proper operating temp, and these drips are also basically harmless!!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Jun 2016
    Phoenix
    I have the same problem. I am getting ready to strip bike down to find the leak. when sitting on bike, hubby got down on my right side of bike, middle front. which side is the fuel filter on, right side (while sitting on bike). Fuel filter is on the right side of bike. One of the clamps to the Y was not tight....cleaned it up and put on red thread locker. no leak. The Y is part no. 709000453 for $11.88 you can find them cheaper at a hose supplier store. the y is for a 7.99 mm hose. the fuel filter is 219800056 $19.49 ride now. Ride now sells 6ft of fuel hose for $25
