Results 1 to 12 of 12
    Nov 2018
    San Luis Obispo, CA
    Default Power steering question
    Did the earlier RT models have power steering? I rode a friend's RT yesterday. I forgot what year he told me it was, I think he said 2010. It seemed to steer somewhat hard.
    Dave
    Very Active Member 4 MARIE's Avatar
    Apr 2014
    Beloit Kansas
    they DID have power steering. Which is supposedly speed-sensitive, faster you go, the less boost you need.
    I had two 2014 RTs (totaled the 1st one). The steering effort was markedly different between the two, and they were the same model year.
    Flatlander, Navy Veteran, Widower
    Loved my 2014 RTS SE6 Pearl white
    but have a new love now,
    my 2017 RTS SE6 Champagne metallic (Champ)
    Default ALL but the ryker....
    It's labeled DPS (dynamic power steering) and is an electric assist that will decrease as you pick up speed. Many who have a heavier feel to them in many cases are running lower air pressure in the front tires but being an expensive unit and around that year they had problems it may very well be bad... anyway they all have the DPS except the Ryker guessing its design and weight made them decide not to use it. If they did add it the price would be well over the goal set...
    ​2012 RS sm5
    There have been some changes to the DPS in the last couple of years. My 2018's steering was much easier, than that of my 2014, or 2010.
    Very Active Member KX5062's Avatar
    Aug 2012
    Central Coast, CA
    Correct. The earlier Spyders had DPS I and the newer Spyders have DPS II, which requires far less effort. As I understand it, the older models can not be retrofitted. (at least not reasonably) IIRC, the change over occurred in mid year 2017.
    2020 RTL SE6
    Nov 2018
    Lisbon, Portugal
    How does it work while idling?
    Because sometimes I feel it's there and other times not (F3S MY2018)...
    Might have to do with the type of floor... It's clearly assisted when I'm maneuvering on the garage (epoxy floor) and seems I can't move it while on tarmac.
    2018 F3S , Monolith Black Satin
    Active Member SpyderJerry's Avatar
    Aug 2017
    Deerfield, Wi
    Quote Originally Posted by MakoShark2 View Post
    My Rt 2013 does not assist until in gear and starting to move.
    2014 RT SE6
    Jul 2018
    Germany
    Quote Originally Posted by SpyderJerry View Post
    I ride an STS from 2013 and its working like yours
    R
    2014 STS SE5 , circuit yellow (metallic)
    Nov 2018
    Lisbon, Portugal
    Quote Originally Posted by germanspyderrider View Post
    R
    Ah... Might have to do with that then, which makes sense.
    Thanks guys!
    Sep 2009
    La Valle, WI
    My 2018 F3 limited steers easy at idle on any surface. My previous 2015 RTS would not turn at idle till I started to move.
    2018 F3 Limited , Oxford Blue
    Nov 2018
    Claremore, Ok.
    I've reading my new Shop Manual for my 2015 RTS. It says the DPS/VSS is calibrated for the BRP approved tires and the VSS will become ineffective if the front tires aren't approved by BRP.
    Could one of you guys kick me in the ass BEFORE I EVER buy another machine as complicated as these Spyders or like my 2014 Triumph Trophy.
    Quote Originally Posted by Revalden View Post
    Total - HOOEY - and that tire/computer info has been proven to be False.....Don't drink all the Koo-Aide , good luck …. Mike
