Results 1 to 13 of 13
    Active Member spyderjim's Avatar
    nowhere
    Default 2016 F3 Limited air valve under passenger seat??
    I just purchased a used 2016 F3 Limited. Under the passenger seat is an air valve. I checked the pressure and it is zero. What is this valve for and how much pressure should there be?
    Smile & be happy, don't take life too seriously….
    Life moves pretty fast. Don't miss it!
    2016 F3 Limited , Black
    Apr 2017
    North Central Florida
    If you don't have an owners manual, you should get one.
    There is an air spring/shock in the rear suspension.
    Some operate semi-automatically and some you have to add air manually.
    I think the minimum recommended pressure is something around 4 PSI.
    Bryant, Arkansas
    Maximum should be around 60 PSI
    Air ride suspension air bag
    Cruzr Joe
    Jun 2010
    Las Vegas
    There is a chart in the manual, along with a sticker near the valve, thst show the recommended settings for the air bag. You need to check it fairly often as they lose pressure.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Apr 2017
    Quote Originally Posted by SpyderAnn01 View Post
    That's good to know.
    The first RT I bought used had the switch on the dashboard and did NOT have the sticker by the valve...............
    But displayed a failure message when the switch was pushed.
    And the dealer I bought it from said that it did not HAVE the automatic feature.
    Turns out that was not true.
    Jun 2016
    Harrington, Australia
    I have to admit that I really don’t understand the exact purpose of the air bag. It sits on top of the shock, which does all the work. Is it simply to cushion the effect of your shock bottoming out? Is it simply to add ride height? Now that I am running Wilber shocks, which have eliminated ANY bottoming out on my 16 F3-L, I have run the air bag at 65psi and 5 psi, and have experienced zero difference in ride quality.
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Apr 2017
    Mostly. The shock works best when it starts out "centered".
    It should PREVENT the shock from bottoming out in some situations......if used properly.
    Jul 2014
    Mint Hill, NC
    Go to this link, drill down to your model and read page 51, http://www.operatorsguides.brp.com/I...adster&type=og.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    nowhere
    Thanks to all!! I did not get a manual with the F3. However, I went to the BRP site and found the manual.....bad news is BRP will not let you download it to a PDF. I did find a different site where I could download to a PDF, but it is not for a F3 Limited, which leaves out a lot. Also, here is a photo of the label next to the valve. What the heck does that mean?? I filled it to 30PSI, and I'll see how that works.
    Apr 2017
    Quote Originally Posted by spyderjim View Post
    I did not get a manual with the F3. Also, here is a photo of the label next to the valve.
    If you got it from a dealer, they should get you a manual free of charge.
    If from an individual, you should go back and give him 10 lashes for losing it.
    Should be able to buy one from a dealer fairy cheap.
    That is not the label in question. That one is part numbers for something, I think.
    Is there not another label nearby ?
    Active Member OkieDoc's Avatar
    Oct 2013
    Oklahoma
    You should have this decal under your passenger seat with this information on it. It shows the airbag pressure recommended for the load being carried.
    I weight just under 250lb and maybe have 10lbs of gear in the bags, so I run about 50psi in my airbag.
    2017 F3-T SM6, Intense Pearl Red, SpyderPops Run/Turn/Brake, Baja Ron Sway Bar and Skid Plate, 21 Inch Tinted F4, Signature Light, Tricled LED Headlights Yokohoma S-Drive, Ultimate Tall Boy.
    nowhere
    NOPE! There is now......I printed the label and taped it under the seat.
    Active Member SpyderNeil's Avatar
    Jul 2015
    Kamloops B C
    Here is a link to the manuals:
    http://www.operatorsguides.brp.com/Index.aspx
    Yours is listed under roadster.
    2020 Harley Davidson Tri Glide Ultra
    2017 F3-T SE6 White / BRP Backrest / Nuvi 58 LM / Polaris Spring Spacers / CALSCI 22" Shield
    2016 RTE6 , Black
