Results 1 to 7 of 7
    Nov 2018
    N.E. Ohio
    Default Rally Edition passenger seat question
    I read where the Rally Mode will not engage when rear pegs are down. Is there a plug and play electrical cord attached to the passenger seat to make this happen? Thanks, cueman
    Default Possibly....
    Could be much like the passanger switch under the seat on all other models. Time will tell but I would think they are doings this for some safety reason and are not recommending ryding ralley with a passenger... but then I do all the hairbrained stuff when alone not putting anyone at risk for my foolishness... you can probably give your passenger a thrill even without the ralley mode....
    ​2012 RS sm5
    Very Active Member Grandpot's Avatar
    Oct 2014
    Fort Mill, SC
    The feedback from the peg switches most likely are part of the control for the VSS and ABS systems to allow for the weight of a passenger. May not be a good idea to mess with it.
    2011 RTS (Sold to a very nice lady)
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    SC Law Enforcement Boat Captain
    CNC Machine Service Technician
    President: Rolling Thunder SC1
    Member: Disabled American Veterans, Rock Hill, SC
    Member: American Legion
    Experience is recognizing the same mistake every time you make it!
    Nov 2018
    N.E. Ohio
    Thanks Folks, I don’t want to mess with it, I never had a Can Am before, except in a boat, and wondered if it was plug and play. cueman
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    Interesting...I never thought of that, but it makes a lot of sense.
    Dec 2018
    NY
    Per the manual, there is a magnetic switch in the left foot peg that activates when the peg is lowered. This tells the VSS system to change settings due to the extra weight and altered center of gravity. You are correct that sport mode and rally mode are not available with a passenger on board (don't want to tip or through someone off the bike)
    2022 F3S, special series , Manta Green
    May 2017
    Mesa, Arid-Zone-A
    BRP has a long track record of electrically altering vehicle performance based upon various inputs. Back in 2012, I bought a CanAm Commander side by side. It came with 2 keys. One was the "standard" and the other was the "performance" key. The standard key limited power output to about 60% and throttle sensitivity was greatly reduced. The performance key restored power but still had throttle sensitivity reduced. The elimination of sensitivity was important in order to maintain control when doing rock climbing. Bouncing around when going up and down rocks was made a lot easier and safer by not having a jerkey throttle. Then there was a switch that put the vehicle into "sport" mode which overrode everything and gave full response and power. In addition, there was a feature that limited speed to 12MPH if the seat belt was not fastened.
    Point is, BRP has been electronically adjusting vehicle performance based upon various input criteria for a long time. I found that my riding expertise increased dramatically after learning how to properly deal with different bike settings based upon how the vehicle is being used/loaded ..... Jim
    Semper Fi
