Results 1 to 11 of 11
    Active Member Cruising RT's Avatar
    Dec 2014
    United States
    Spyder Sena RC-4 Handlebar Remote
    Anyone mounted a Sena RC-4 remote on a Spyder RT? I have a 14' RTL SE6, so I'm not able to mount on left grip due to changing gears. I am about to purchase the Sena SRL bluetooth for my Shoei Neotec II helmet and would like to add a handlebar remote. Any suggestions & photos would be Awesome. Thanks in advance for your time.
    Nov 2018
    Des Moines IA
    I have the original handlebar remote and have the same problem. It will clip on the dash or it has to be stored in the glove box. Mu guess is that the RC-4 has to be on a pipe of some kind due to the new shape.
    2018 Spyder ST Limited , Asphalt Gray
    Sep 2017
    Indy
    Quote Originally Posted by Cruising RT View Post
    I've had two of those for the wife's 30K on her F3T it works for about 30 minutes and then just disconnects, even tried it with my SRL and similar results. Initial connection and usage is as it should be but after just a short while its no worky ):
    Mar 2013
    I was going to purchase 2 of them (1 for each F3), but noticed the issue with mounting them with the paddle shifters. Decided to go with the RC3 as those can be mounted on any flat serfaces, and the buttons are larger for use with gloves.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Dec 2014
    United States
    Spyder
    Quote Originally Posted by PW2013STL View Post
    I have the Shoei Neotec II and I’m under the impression that the SRL system is basically the same as a Sena 20S so I think my only remote control option is the Sena RC4, May be wrong.
    Nov 2018
    Des Moines IA
    I contacted Sena. All remotes are suppose to work with all models. At least that is what they told me.
    Mar 2013
    The RC3 is listed as working with all their intercoms.
    Member WaynoJ's Avatar
    Mar 2017
    Mill Creek, WA and Surprise, AZ
    I have an RC-4 mounted on the left grip of my '18 RTL SE6, controling the SRL in my NeoTec II, with no problems shifting. Are you afraid it will interfere with the shifter? Doesn't on mine.
    I think I am, therefore I am. I think.
    George Carlin
    '18 RT Limited Dark - Champagne
    '15 ST-S White/Orange (sold)
    '14 Ducati Monster 1200 (rear-ended)
    '12 Triumph Street Triple R (sold)
    '99 BMW R1100S (sold)
    2018 RT Limited , Champagne
    Dec 2015
    Oakley Utah
    Quote Originally Posted by WaynoJ View Post
    Can you post a pic of how you have it mounted?
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    This doesn't really answer the question, but I found this video helpful.
    https://www.youtube.com/watch?v=OayOlaiWmu8
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    Motorcycle Dave, can you explain the differences between Sena's 4 different communicator remote controls? I would definitely like to get one of these handy devices but choosing which one is a problem. Thanks.
    2014 RTL Platinum
Tags for this Thread
