Page 2 of 2 FirstFirst 12
Results 26 to 29 of 29
  1. #26
    Feb 2012
    Spring City,Utah
    If you have squeaky breaks and you are under warranty take it to dealer and have them fix it. It should be a warranty issue. If no warranty go to NAPA and get a tube of anti squeal and put on back of pads. Should help.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
  2. #27
    Apr 2017
    North Central Florida
    Quote Originally Posted by BioAbyssal View Post
    Update: So far from has been said the “Scuffing” noise on the left side is normal. Honestly, I doubt that.
    And I doubt that you are right.
    Even cars have light scraping noises coming from the disc brakes sometimes.......you just can't hear it from inside.
    Other owners have said: "Probably normal".
    Now a mechanic has said the same thing.
    What more do you WANT ??
  3. #28
    May 2018
    millsboro,delaware
    One more thing that hasn’t been mentioned is that when brakes are made they are sprayed with an epoxy on the metal side to keep them from rusting and if that spray gets on the edge of the pad it may cause a squeak,scuff or chirp noise.Also sometimes the pad itself has a little too much metallic content which usually can be seen upon inspection of pad.I would advise to swap the pads from left to right and see what happens.
    : 2017 RTL ORBITAL BLUE
  4. #29
    Nov 2017
    San Francisco Bay area
    FWIW my scuffing noise was said to be metal on metal due to worn left brake pad. Both pads were replaced and no scuffing noise. I will say the noise never sounded like the noise you get with car brakes.
    2015 Pearl White RTL
    Baja Ron Sway Bar
    Russell Day Long Seat
    Strobe Brake Light
    Mirror Mount Turn Signal Indicator
    2015 RTL , Yes Pearl White
Tags for this Thread
