Any fix for 2015 RTS poor / no AM/FM radio reception?
Radio reception is poor or non-existent for both AM and FM bands. This it is not a location issue because my Goldwing parked next to the Spyder gets great reception. I did check the antenna connection and ground and all appears fine. The sound system works fine with an Ipod. Any ideas?
Do you have a p/n for that antennae?I switched my stock out for a two footish HD one that worked well on my V but still could be much better!
Unfortunately because the purchase ( on E-bay ) was so long ago it's not on file anymore...…. I'm sure any quality after market Manual re-tractable auto ant. will be a hugh improvement ………… Before you make a purchase - take the right side Speaker pod off and measure how much Depth you have for the antenna, most are from 7 to 9 inches. ……… good luck …. mike
I've tried a couple of different antenna solutions on my two 1330 TS... Nothing ever worked.
Scraping the antenna base threads helped a little bit; certainly not enough.
But I live in an area where FM reception can be problematic in any vehicle: it's just worse with the Spyders.
Curiously: my 2010 RT had the best reception of my three bikes. I wonder what they changed in the sound system?
2016 RT-S SE6, Radio reception is always a problem. Solution, a good bluetooth radio receiver and Siriusxm. Works great and know no issues. Patrick Kane
I have a 2018 rtl ,and the reception is terrible .It is about the same as my freecom head set .
