Results 1 to 13 of 13
    Indy
    Arrow Mirror Turn Signal Lights.
    I'm wanting to install a LED strip to the mirrors but only want them as signals only no running, I've tested trying to use them with the existing factory ones and that's not working. Question will I need to run power to the rear signals since I'm thinking they are 12 volts or is there somewhere closer to the front I can tap into?
    Enjoy the holidays.
    Dec 2015
    Oakley Utah
    Quote Originally Posted by h100250 View Post
    Enjoy the holidays.
    All the ones I've seen are turn signals only. Plug 'n play pretty much. Try Tricled.com ?
    2014 RTL Platinum
    Mar 2013
    On my 2014 I just taped off the wires going into the mirrors. They only blinked when the turn signal blinked - no running light.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Unhappy Try This....
    Most just tap into the turnsignal wires (mind you positive to positive and negative to negative) and only work as turnsignals. If your OEM are both runing lights and turnsignal you have to find the wire for the turn signal side
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Oct 2013
    Wood Village OR
    Default Turn Signal Lights
    I have done all four of out RTLs and it only takes about an hour if you have everything ready . I splice into the existing wires and make sure i solder them and use heat shrink covers.
    Spyder Farkels and eagles 001.jpg Spyder Farkels and eagles 004.jpg Spyder Farkels and eagles 015.jpg
    2014 RTL , Black Currant
    Dec 2015
    Oakley Utah
    Quote Originally Posted by easysuper View Post
    The impact wrench is probably for a different project, I think?
    2014 RTL Platinum
    Danbury Connecticut
    Enjoy the holidays.
    What's not working ?
    Please understand, unlike incandescent lights, LEDs are circuits. You have to connect the wires correctly, + to + and - to -.
    The LEDs follow the 50/50/90 rule. If you have a 50/50 chance of connecting them right, you have a 90% chance of connecting them wrong.
    If the LEDs are connected and they don't work, just follow the advice of every Star Trek engineer from Scotty on forward and reverse the polarity.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Apr 2017
    North Central Florida
    There was a flaw in your testing somehow.
    If what you are trying to use draws too much current, it will mess up the operation of the signals.
    TricLed has a set that bridge right onto the wires for the front turn signals.
    Not technically 100% "plug and play" but the installation is fairly easy.
    May 2017
    Mesa, Arid-Zone-A
    I have plug and play. They are attached to the outer edge of the mirrors and go all the way from top outer corner to the bottom of the mirror. There is a notch in the bottom of the mirror frame that the wire fits in nicely without the need to drill any holes. They only function as turn signals. VERY visible from front, side, & rear. One of the very best safety features. And, unlike the weak dash turn indectors, I can see them when I forget to cancel my turn signals.
    Semper Fi
    with those who have DIY'ed their mirrors with LED's ( Soldering and heat shrink tubing ) ….. If you really want to save money check out this seller ….BANGGOOD.COM ….. They have 3 and 6 LED mini strips in different colors and their Heat Shrink tubing is sold at BARGAIN prices compared to even Home Depot ….. Mike
    Oct 2015
    Lynden, WA
    1+ on Banggood.com
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Oct 2013
    Wood Village OR
    Actually that is a very small drill motor that has a matching impact driver. I used it to drill the tiny hole for the LED wires on the bottom edge of the mirror. I also had on the table the female adapters that I mounted on the tupper ware.
    Nowhere
    I used a pair of cheap, yellow LEDs and used a set of connectors to create a y in the circuit. The feed from the bus splits and feeds both the mirror lights and my add on LEDs. If the add on LEDs ever require replacing (or a dealer gets snooty about add ins causing a problem) I can remove them from the circuit by unplugging them. Cost a bit more than Mikes solution above but it still works.
    "If you can't be a good example, then you'll just have to be a horrible warning." Catherine Aird
