Results 1 to 10 of 10
Thread: Echo modw
    Nov 2018
    Chicago
    Default Echo modw
    What is echo mode on 2018 f3. Is it just shift indicator or something more
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Beer8 View Post
    'ECO mode' (economy mode) also makes changes to the ECU that affect acceleration, I believe.
    2014 RTL Platinum
    ECO mode has a green arrow that tells you when to upshift or downshift. Your F3 has a 1330 engine. "Most" find that shifting in the 3500 RPM or so range is optimum. Find the sweet spot on your bike and you will be good.
    Most do not use the ECO function. It distracts from the driving when you are watching for the arrow. Actual savings in gas reported by most is 1 MPG or so per tank. I used it faithfully for one tank to see what it was all about. I let the bike downshift on its own--no ECO telling me when.
    At my "sweet spot" the upshifts are seamless. Learn to drive by "ear" and "feel" and you will be a bit happier--IMO of course.
    You can over ride the system any time you need to.
    Active Member starrider60's Avatar
    Aug 2017
    laurel, mississippi
    Default no more ECO for me
    I tried the ECO thing early in my Spyder learning period. No more. Distracted me from the fun of riding
    Jul 2014
    Mint Hill, NC
    Here's what the ECO Mode does to acceleration.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Aug 2008
    MA & NH
    Do not use, do not like it.
    Mar 2015
    forrest above Reno, Nv
    Waste of a perfectly good button
    2014 RTS , Circuit Yellow
    I tried it out on my 2014 RT-L: it only gained me one-tenth of a mpg!
    But it DID manage to distract me from looking where I should have been: you end up staring at the dash: instead of what's in the road in front of you...
    Quote Originally Posted by Lew L View Post
    And my favorite rant: They took away the trunk release button which worked fine and everyone that had one used it.
    Nov 2018
    Northern NV
    I've been using the Eco mode on my F3T just to get used to three wheels vs. two... found out today that it doesn't do much for wheelspin on a wet roadway at low speed. Okay, I found out on purpose - but I think it's time to turn it off. I agree with it being a waste of a button position.
    2017 F3T , Black, black and more black
